thinkgeo.mapsuite.core.requestingdatawfsfeaturesourceeventargs
ThinkGeo.MapSuite.Core.RequestingDataWfsFeatureSourceEventArgs
<!– Class –> This class represents the parameters passed in through the RequestingData event in WfsFeatureSource.
Public MethodRequestingDataWfsFeatureSourceEventArgs This is a default constructor for the class.
Public MethodRequestingDataWfsFeatureSourceEventArgs String, Boolean, String This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyOverrideResponse Boolean This property gets or sets the override mode. If set it ture, we will replace the response with new XmlResponse String passed in.
Public PropertyServiceUrl String This property gets or sets the serviceUrl for the WfsFeatureSource.
Public PropertyXmlResponse String This property gets or sets the xml response string back from for the WfsFeatureSource service url.
RequestingDataWfsFeatureSourceEventArgs()
Name Type Description
Go Back
RequestingDataWfsFeatureSourceEventArgs(String, Boolean, String)
serviceUrl String<!– System.String –> This parameter specified the serviceUrl for the WfsFeatureSource.
overrideResponse Boolean<!– System.Boolean –> This parameter specified if we need to override Response if we changed the response string.
xmlResponse String<!– System.String –> This parameter specified the xmlResponse string get back from the service Url.
Go Back
Return Type Description
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
OverrideResponse
Return Type
<!– ThinkGeo.MapSuite.Core.RequestingDataWfsFeatureSourceEventArgs –> Go Back
ServiceUrl
Return Type
XmlResponse
Return Type
thinkgeo.mapsuite.core.requestingdatawfsfeaturesourceeventargs.1440040129.txt.gz · Last modified: 2015/09/17 10:38 (external edit)
