This class represents a single Regex Match statement and styles to draw.
If you use this constructor, you should set the necessary properties manually.
It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultAreaStyle.
regularExpression
It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultLineStyle.
regularExpression
It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultPointStyle.
regularExpression
It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultTextStyle.
regularExpression
It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the CustomStyles.
regularExpression
This property gets the collection of custom styles.
The custom styles allow you to use styles other than the default style properties of the class. In this way, you can use a DotDensityStyle or any other style in the API.
This property gets and sets the default AreaStyle. You should use this style if your features are area-based.
The default style allows you to directly set properties on the styles without having to create a new style each time. You can start simply by setting properties like color, etc. This makes modifying styles very easy.
This property gets and sets the default LineStyle. You should use this style if your features are line-based.
This property gets and sets the default PointStyle. You should use this style if your features are point-based.
Return Type:PointStyle
This property gets and sets the default TextStyle. You should use this style if your features are text-based (such as labels).
This property gets and sets the regular expression text used for matching.
This should be a valid regular expression string. Formatting regular expression strings is outside the scope of this documentation; however, there are many useful resources on the web for learning about regular expressions.
Return Type:String
