<!– Class –> This class represents the parameters passed in through the BuildingIndex event in ShapeFileFeatureSource class.
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.RebuildingShapeFileFeatureSourceEventArgs
RebuildingShapeFileFeatureSourceEventArgs | This is the default constructor of the event args. | ||
RebuildingShapeFileFeatureSourceEventArgs | Int32, Int32, Feature, DateTime, Boolean | This is the constructor of the event args by passing the desired parameters. | |
RebuildingShapeFileFeatureSourceEventArgs | Int32, Int32, Feature, DateTime, Boolean, String |
Cancel | Boolean | Gets or sets to see if we need to cancel the building index of current record. | |
CurrentFeature | Feature | Gets the current feature for building rTree index. | |
CurrentRecordIndex | Int32 | Gets the current record index for building rTree index. | |
RecordCount | Int32 | Gets the total record count to build rTree index. | |
ShapePathFilename | String | ||
StartProcessTime | DateTime | Gets the starting process time for building the index. |
If you use this constructor, you have to set the properties manually.
| recordCount | Int32<!– System.Int32 –> | |
| currentRecordIndex | Int32<!– System.Int32 –> | |
| currentFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | |
| startProcessTime | DateTime<!– System.DateTime –> | |
| cancel | Boolean<!– System.Boolean –> |
| cancel | Boolean<!– System.Boolean –> | |
| shapePathFilename | String<!– System.String –> |
<!– ThinkGeo.MapSuite.Core.RebuildingShapeFileFeatureSourceEventArgs –> Go Back
