<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.PrinterLayer ThinkGeo.MapSuite.Core.DataGridPrinterLayer ThinkGeo.MapSuite.Core.ImagePrinterLayer ThinkGeo.MapSuite.Core.LabelPrinterLayer ThinkGeo.MapSuite.Core.LegendPrinterLayer ThinkGeo.MapSuite.Core.MagneticDeclinationPrinterLayer ThinkGeo.MapSuite.Core.MapPrinterLayer ThinkGeo.MapSuite.Core.PagePrinterLayer ThinkGeo.MapSuite.Core.ScaleBarPrinterLayer ThinkGeo.MapSuite.Core.ScaleLinePrinterLayer ThinkGeo.MapSuite.Core.ScaleTextPrinterLayer
PrinterLayer |
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer(overriden) | ||
GetPositionCore | PrintingUnit | ||
MemberwiseClone | Object | ||
OpenCore | Layer | This method opens the Layer so that it is initialized and ready to use. | |
SetPositionCore | Double, Double, Double, Double, PrintingUnit |
BackgroundMask | AreaStyle | ||
DragMode | PrinterDragMode | ||
HasBoundingBox | Boolean | Layer(overriden) | |
IsDrawing | Boolean | ||
ResizeMode | PrinterResizeMode | ||
SelectabilityMode | SelectabilityMode | ||
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
This method draws the Layer.
This method returns the bounding box of the Layer.
| unit | PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –> |
<!– ThinkGeo.MapSuite.Core.PrinterLayer –> Go Back
<!– static –>
<!– static –>
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| width | Double<!– System.Double –> | |
| height | Double<!– System.Double –> | |
| centerPointX | Double<!– System.Double –> | |
| centerPointY | Double<!– System.Double –> | |
| corner | LayerAnchorLocation<!– ThinkGeo.MapSuite.Core.LayerAnchorLocation –> | |
| cornerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| cornerPointX | Double<!– System.Double –> | |
| cornerPointY | Double<!– System.Double –> | |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| centerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
| PrinterDragMode<!– ThinkGeo.MapSuite.Core.PrinterDragMode –> |
| PrinterResizeMode<!– ThinkGeo.MapSuite.Core.PrinterResizeMode –> |
| SelectabilityMode<!– ThinkGeo.MapSuite.Core.SelectabilityMode –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
