thinkgeo.mapsuite.core.oraclefeaturelayer
Table of Contents
ThinkGeo.MapSuite.Core.OracleFeatureLayer
<!– Class –> This class represents a Layer backed by Oracle Spatial.
Public MethodOracleFeatureLayer This is the constructor for the class.
Public MethodOracleFeatureLayer String, String, String This is the constructor for the class.
Public MethodOracleFeatureLayer String, String, String, DatabaseConnectionMode
Public MethodBuildIndex
Public MethodBuildIndex BuildIndexMode
Public MethodCloneDeep Layer Create a copy of Layer using the deep clone process.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodExecuteNonQuery String This method executes a query that does not return a SQL result.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetType Object
Public MethodStatic MemberLoadLayer Uri Layer
Public MethodStatic MemberLoadLayer Stream Layer
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodRequestDrawing Layer
Public MethodRequestDrawing IEnumerable<RectangleShape> Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing TimeSpan Layer
Public MethodRequestDrawing TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing RectangleShape, TimeSpan Layer
Public MethodRequestDrawing RectangleShape, TimeSpan, RequestDrawingBufferTimeType Layer
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Layer
Public MethodRequestDrawing RectangleShape Layer
Public MethodToString Object
Protected MethodCloneDeepCore Layer Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
Protected MethodCloseCore Layer(overriden)
Protected MethodDrawAttributionCore GeoCanvas, String Layer
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden)
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden)
Protected MethodOnDrawingAttribution DrawingAttributionLayerEventArgs Layer
Protected MethodOnDrawingException DrawingExceptionLayerEventArgs Layer
Protected MethodOnDrawingFeatures DrawingFeaturesEventArgs FeatureLayer This method raises the DrawingFeatures event.
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawingWrappingFeatures DrawingWrappingFeaturesFeatureLayerEventArgs FeatureLayer
Protected MethodOnDrawnAttribution DrawnAttributionLayerEventArgs Layer
Protected MethodOnDrawnException DrawnExceptionLayerEventArgs Layer
Protected MethodOnRequestedDrawing RequestedDrawingLayerEventArgs Layer
Protected MethodOnRequestingDrawing RequestingDrawingLayerEventArgs Layer
Protected MethodOpenCore Layer(overriden)
Protected MethodSetupTools FeatureLayer This method sets up the EditTools and QueryTools objects.
Protected MethodSetupToolsCore FeatureLayer This method sets up the EditTools and QueryTools objects.
Public PropertyAttribution String Layer
Public PropertyBlueTranslation Single Layer This property gets and sets the amount of blue to apply to the image.
Public PropertyCommandTimeout Int32 This property gets and sets the amount of time that can elapse before the command will timeout and abort.
Public PropertyConnectionString String This property gets and sets the connection string that will be used to connect to the server.
Public PropertyDatabaseConnectionMode DatabaseConnectionMode
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingMarginInPixel Single FeatureLayer
Public PropertyDrawingQuality DrawingQuality FeatureLayer This property gets and sets the general drawing quality for the FeatureLayer's canvas.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyEditTools EditTools FeatureLayer This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer.
Public PropertyFeatureIdColumn String This property gets or sets the name of the column that holds the unique feature Id.
Public PropertyFeatureIdsToExclude Collection<String> FeatureLayer A collection of strings representing record id of features not to get in the Layer.
Public PropertyFeatureSource FeatureSource FeatureLayer This property gets the FeatureSource for the FeatureLayer.
Public PropertyGeometryValidationMode GeometryValidationMode FeatureLayer
Public PropertyGreenTranslation Single Layer This property gets and sets the amount of green to apply to the image.
Public PropertyHasBoundingBox Boolean Layer(overriden) This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In OracleFeatureLayer, we override this API and mark it as true.
Public PropertyIsGrayscale Boolean Layer This property gets and sets if the image should be converted to grayscale.
Public PropertyIsNegative Boolean Layer This property gets and sets whether the image should be converted to negative (inverse colors).
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyKeyColors Collection<GeoColor> Layer Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors.
Public PropertyMaxRecordsToDraw Int32 FeatureLayer
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyQueryTools QueryTools FeatureLayer This property gets the QueryTools that allow you to easily query Features from the Feature Layer.
Public PropertyRedTranslation Single Layer This property gets and sets the amount of red to apply to the image.
Public PropertyRequestDrawingInterval TimeSpan Layer
Public PropertyTableName String This property gets or sets the table name the database will use.
Public PropertyTransparency Single Layer This property gets and sets the amount of transparency to apply to the image.
Public PropertyWhereClause String
Public PropertyWrappingExtent RectangleShape FeatureLayer
Public PropertyWrappingMode WrappingMode FeatureLayer Thie property gets or sets whether allow wrap date line.
Public PropertyZoomLevelSet ZoomLevelSet FeatureLayer This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer.
Protected PropertyIsOpenCore Boolean Layer(overriden)
OracleFeatureLayer()
Overloads
This is the default constructor, but it is not typically used.
Name Type Description
Go Back
OracleFeatureLayer(String, String, String)
Overloads
This constructor allows you to pass in all of the data to create the Layer.
connectionString String<!– System.String –> This parameter represents the connection string that will be used to connect to the server.
tableName String<!– System.String –> This parameter represents the table name being accessed.
featureIdColumn String<!– System.String –> This parameter represents the name of the column that holds the unique feature Id.
Go Back
OracleFeatureLayer(String, String, String, DatabaseConnectionMode)
databaseConnectionMode DatabaseConnectionMode<!– ThinkGeo.MapSuite.Core.DatabaseConnectionMode –>
Go Back
BuildIndex()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.Core.OracleFeatureLayer –> Go Back
BuildIndex(BuildIndexMode)
mode BuildIndexMode<!– ThinkGeo.MapSuite.Core.BuildIndexMode –>
CloneDeep()
Layer<!– ThinkGeo.MapSuite.Core.Layer –> A cloned Layer.
Close()
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
ExecuteNonQuery(String)
This methods executes a query that has no results.
Int32<!– System.Int32 –>
sqlStatement String<!– System.String –> This parameter represents the SQL statement that will be executed.
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This method returns the bounding box of the Layer.
Type<!– System.Type –>
LoadLayer(Uri)
<!– static –>
layerUri Uri<!– System.Uri –>
LoadLayer(Stream)
<!– static –>
layerStream Stream<!– System.IO.Stream –>
Open()
RequestDrawing()
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
bufferTime TimeSpan<!– System.TimeSpan –>
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing(TimeSpan)
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(RectangleShape, TimeSpan)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
CloneDeepCore()
CloseCore()
DrawAttributionCore(GeoCanvas, String)
attribution String<!– System.String –>
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
args DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –>
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –>
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
e DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.Core.DrawingFeaturesEventArgs –> This parameter represents the event arguments for the event.
<!– ThinkGeo.MapSuite.Core.FeatureLayer –> Go Back
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –>
e DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingWrappingFeaturesFeatureLayerEventArgs –>
args DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –>
eventArgs RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –>
eventArgs RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –>
OpenCore()
SetupTools()
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
SetupToolsCore()
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
Attribution
Return Type
BlueTranslation
Return Type
Single<!– System.Single –>
CommandTimeout
You can use this to set a time limit for the query before it times out.
Return Type
ConnectionString
Return Type
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
Return Type
DrawingQuality
The DrawingQuality enumeration allows you to control, in a macro sense, the drawing quality that will be used in the GeoCanvas. Each GeoCanvas, which is responsible for drawing of the features, may have its own specialized drawing quality properties. What the DrawingQuality enumeration does is define some general guidelines for each GeoCanvas. For example, if you set the DrawingQuality to HighSpeed, then inside of the GdiPlusGeoCanvas there is a profile for HighSpeed. This profile sets specific properties, such as the smoothing mode and composing drawing mode of the GdiPlusGeoCanvas. As each GeoCanvas may have different drawing quality properties, this offers a general way to control drawing quality and speed.
If you need complete control over how a specific GeoCanvas will draw, then you can set the DrawingQuality to Custom. This will tell the specific GeoCanvas to use the properties on its own object instead of one of the pre-defined profiles. If one of the profiles – such as HighSpeed or HighQuality – is set, then the specific GeoCanvas ignores its own properties for drawing quality.
Return Type
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –>
DrawingTime
Return Type
EditTools
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
Return Type
EditTools<!– ThinkGeo.MapSuite.Core.EditTools –>
FeatureIdColumn
Return Type
FeatureIdsToExclude
Return Type
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
FeatureSource
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
Return Type
FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –>
Return Type
GeometryValidationMode<!– ThinkGeo.MapSuite.Core.GeometryValidationMode –>
GreenTranslation
Return Type
HasBoundingBox
Return Type
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
Return Type
IsVisible
Return Type
KeyColors
Return Type
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –>
MaxRecordsToDraw
Return Type
Return Type
QueryTools
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
Return Type
QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –>
RedTranslation
Return Type
Return Type
TableName
Return Type
Transparency
Return Type
WhereClause
Return Type
WrappingExtent
Return Type
WrappingMode
Return Type
WrappingMode<!– ThinkGeo.MapSuite.Core.WrappingMode –>
ZoomLevelSet
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
Return Type
ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –>
IsOpenCore
Return Type
DrawingAttribution
Event Arguments
Event Arguments
DrawingException
Event Arguments
Event Arguments
DrawingFeatures
This event is raised when features are about to be drawn in the layer.
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
thinkgeo.mapsuite.core.oraclefeaturelayer.1440040129.txt.gz · Last modified: 2015/09/17 10:36 (external edit)
