thinkgeo.mapsuite.core.northdeclineresult
ThinkGeo.MapSuite.Core.NorthDeclineResult
article_rating
<!– Structure –> (This class is not finally released, it is possible to be removed in the next public release)
Public Method*Equals Object Object(overriden)
Public Method*GetHashCode Object(overriden)
Public Method*GetType Object
Public Method*ToString Object(overriden)
Protected Method*Finalize Object
Protected Method*MemberwiseClone Object
Public Property*CentralMeridian Double
Public Property*ChangeByYear String
Public Property*GeomagneticDeclination Double
Public Property*MagneticDeclination Double
Public Property*Zone String
*Equals(Object)
Return Type Description
Boolean<!– System.Boolean –>
Name Type Description
*GetHashCode()
Int32<!– System.Int32 –>
*GetType()
Type<!– System.Type –>
*ToString()
String<!– System.String –>
*Finalize()
Void<!– System.Void –>
*MemberwiseClone()
*CentralMeridian
Return Type
Double<!– System.Double –>
<!– ThinkGeo.MapSuite.Core.NorthDeclineResult –> Go Back
*ChangeByYear
Return Type
Return Type
Return Type
*Zone
Return Type
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
thinkgeo.mapsuite.core.northdeclineresult.txt · Last modified: 2017/03/16 21:59 (external edit)
