thinkgeo.mapsuite.core.multiplefeaturelayer
ThinkGeo.MapSuite.Core.MultipleFeatureLayer
This class represents a Layer backed by multiple Shape Files.
      • ThinkGeo.MapSuite.Core.FeatureLayer
        • ThinkGeo.MapSuite.Core.MultipleFeatureLayer
MultipleFeatureLayer()
This is the default constructor for the class.
MultipleFeatureLayer(IEnumerable<FeatureSource>)
  • featureSources
    • Type:IEnumerable<FeatureSource>
    • Description:This parameter represents the FeatureSources in this class that you want to use.
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
SetupTools()
SetupToolsCore()
OpenCore()
CloseCore()
GetBoundingBoxCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
FeatureSources
This property gets the FeatureSources you want to use.
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In MultipleFeatureLayer, we override this API and mark it as true.
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
  • Type:Collection<String>
QueryTools
MaxRecordsToDraw
FeatureSource
DrawingQuality
ZoomLevelSet
DrawingMarginPercentage
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
DmU=
  • Type:Int64
FWU=
  • Type:Int64
HGU=
  • Type:TimeSpan
I2U=
  • Type:TimeSpan
IsOpenCore
DrawingFeatures N/A
DrawingWrappingFeatures N/A
DrawingException N/A
DrawingProgressChanged N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
RequestedDrawing N/A
RequestingDrawing N/A
thinkgeo.mapsuite.core.multiplefeaturelayer.1442797661.txt.gz · Last modified: 2015/09/21 01:07 by admin
