Ideally I would want to make this inherit from the FeatureLayer so you could do spatial queries. In the interests of time I inherited from the Layer to make things simple and show the point of how easy it is to extend Map Suite. When we roll this into the main product we may create a FeatureSource and FeatureLayer.
This is the default constructor for the MapShapeLayer.
canvas
labelsInAllLayers
extentsToRefresh
bufferTime
bufferTimeType
extentToRefresh
bufferTime
bufferTimeType
bufferTime
bufferTimeType
extentsToRefresh
bufferTime
This method draws the MapShapeLayer.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas
labelsInAllLayers
Return Type:String
Return Type:Single
Return Type:DrawingExceptionMode
Return Type:TimeSpan
Return Type:Single
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Return Type:Boolean
Get all the map shapes with the keys.
Return Type:String
Return Type:Single
Return Type:Single
Return Type:Boolean
