<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.PrinterLayer ThinkGeo.MapSuite.Core.MagneticDeclinationPrinterLayer
MagneticDeclinationPrinterLayer | |||
MagneticDeclinationPrinterLayer | MapPrinterLayer | ||
MagneticDeclinationPrinterLayer | String, MapPrinterLayer |
BackgroundMask | AreaStyle | PrinterLayer | |
DragMode | PrinterDragMode | PrinterLayer | |
Elevation | Double | ||
ElevationUnit | DistanceUnit | ||
GridNorthLineStyle | LineStyle | ||
HasBoundingBox | Boolean | Layer(overriden) | |
IsDrawing | Boolean | PrinterLayer | |
MagneticFieldPathFilename | String | ||
MagneticNorthLineStyle | LineStyle | ||
MapPrinterLayer | MapPrinterLayer | ||
ProjectionToDecimalDegrees | Projection | ||
ResizeMode | PrinterResizeMode | PrinterLayer | |
SampleDateTime | DateTime | ||
SelectabilityMode | SelectabilityMode | PrinterLayer | |
TextStyle | TextStyle | ||
TrueNorthLineStyle | LineStyle | ||
TrueNorthPointStyle | PointStyle |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
DrawingAttribution | DrawingAttributionLayerEventArgs | Layer | |
DrawingException | DrawingExceptionLayerEventArgs | Layer | |
DrawingProgressChanged | DrawingProgressChangedEventArgs | Layer | |
DrawnAttribution | DrawnAttributionLayerEventArgs | Layer | |
DrawnException | DrawnExceptionLayerEventArgs | Layer | |
RequestedDrawing | RequestedDrawingLayerEventArgs | Layer | |
RequestingDrawing | RequestingDrawingLayerEventArgs | Layer | |
StreamLoading | StreamLoadingEventArgs | This event allows you to pass in your own stream to represent the image. |
| mapPrinterLayer | MapPrinterLayer<!– ThinkGeo.MapSuite.Core.MapPrinterLayer –> |
| magneticFieldPathFilename | String<!– System.String –> | |
Create a copy of Layer using the deep clone process.
This method closes the Layer and releases any resources it was using.
This method draws the Layer.
This method returns the bounding box of the Layer.
<!– static –>
| MagneticDeclination<!– ThinkGeo.MapSuite.Core.MagneticDeclination –> |
| pointFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | |
| elevation | Double<!– System.Double –> | |
| elevationUnit | DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> | |
| sampleDateTime | DateTime<!– System.DateTime –> |
<!– ThinkGeo.MapSuite.Core.MagneticDeclinationPrinterLayer –> Go Back
<!– static –>
| sampleDateTime | DateTime<!– System.DateTime –> | |
<!– static –>
| magneticFieldStream | Stream<!– System.IO.Stream –> |
<!– static –>
| x | Double<!– System.Double –> | |
| y | Double<!– System.Double –> | |
<!– static –>
| point | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
<!– static –>
<!– static –>
<!– static –>
<!– static –>
| unit | PrintingUnit<!– ThinkGeo.MapSuite.Core.PrintingUnit –> |
<!– ThinkGeo.MapSuite.Core.PrinterLayer –> Go Back
<!– static –>
<!– static –>
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| width | Double<!– System.Double –> | |
| height | Double<!– System.Double –> | |
| corner | LayerAnchorLocation<!– ThinkGeo.MapSuite.Core.LayerAnchorLocation –> | |
| cornerPointX | Double<!– System.Double –> | |
| cornerPointY | Double<!– System.Double –> | |
| centerPointX | Double<!– System.Double –> | |
| centerPointY | Double<!– System.Double –> | |
| centerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| boundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| cornerPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
This method allows you to raise the StreamLoading event.
This method allows you to raise the StreamLoading event. Normally events are not accessible to derived classes, so we exposed a way to raise the event as necessary through this protected method.
| e | StreamLoadingEventArgs<!– ThinkGeo.MapSuite.Core.StreamLoadingEventArgs –> | This parameter represents the event arguments you want to raise the StreamLoading event with. |
<!– ThinkGeo.MapSuite.Core.PrinterLayer(overriden) –> Go Back
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
| PrinterDragMode<!– ThinkGeo.MapSuite.Core.PrinterDragMode –> |
| LineStyle<!– ThinkGeo.MapSuite.Core.LineStyle –> |
| Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
| PrinterResizeMode<!– ThinkGeo.MapSuite.Core.PrinterResizeMode –> |
| SelectabilityMode<!– ThinkGeo.MapSuite.Core.SelectabilityMode –> |
| TextStyle<!– ThinkGeo.MapSuite.Core.TextStyle –> |
| PointStyle<!– ThinkGeo.MapSuite.Core.PointStyle –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
