<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.AdornmentLayer ThinkGeo.MapSuite.Core.MagneticDeclinationAdornmentLayer
![]() | ScreenPointF | ||
![]() | AdornmentLocation | ||
![]() | String, AdornmentLocation |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer(overriden) | ||
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | StreamLoadingEventArgs | This method allows you to raise the StreamLoading event. | |
![]() | String | Layer | |
![]() | AreaStyle | AdornmentLayer | |
![]() | Single | Layer | This property gets and sets the amount of blue to apply to the image. |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | Double | ||
![]() | DistanceUnit | ||
![]() | Single | Layer | This property gets and sets the amount of green to apply to the image. |
![]() | LineStyle | ||
![]() | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
![]() | Single | AdornmentLayer | |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Collection<GeoColor> | Layer | Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors. |
![]() | AdornmentLocation | AdornmentLayer | This property gets and sets the drawing location of the AdornmentLayer. |
![]() | String | International Geomagnetic Reference Field (IGRF-11) | |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | Projection | ||
![]() | Single | Layer | This property gets and sets the amount of red to apply to the image. |
![]() | TimeSpan | Layer | |
![]() | DateTime | ||
![]() | TextStyle | ||
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | PointStyle | ||
![]() | Single | AdornmentLayer | This property gets and sets the X pixel offset for the AdornmentLayer. |
![]() | Single | AdornmentLayer | This property gets and sets the Y pixel offset for the AdornmentLayer. |
![]() | StreamLoadingEventArgs | This event allows you to pass in your own stream to represent the image. |
Name | Type | Description |
startPoint | ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> |
adornmentLocation | AdornmentLocation<!– ThinkGeo.MapSuite.Core.AdornmentLocation –> |
magneticFieldPathFilename | String<!– System.String –> | |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.Core.Layer –> | A cloned Layer. |
This method closes the Layer and releases any resources it was using.
Void<!– System.Void –> |
This method draws the Layer.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the Layer. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
adornmentWidth | Single<!– System.Single –> | |
adornmentHeight | Single<!– System.Single –> |
<!– ThinkGeo.MapSuite.Core.AdornmentLayer(overriden) –> Go Back
Int32<!– System.Int32 –> |
<!– static –>
MagneticDeclination<!– ThinkGeo.MapSuite.Core.MagneticDeclination –> |
x | Double<!– System.Double –> | |
y | Double<!– System.Double –> | |
elevation | Double<!– System.Double –> | |
elevationUnit | DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> | |
sampleDateTime | DateTime<!– System.DateTime –> | |
magneticFieldStream | Stream<!– System.IO.Stream –> |
<!– ThinkGeo.MapSuite.Core.MagneticDeclinationAdornmentLayer –> Go Back
<!– static –>
<!– static –>
pointFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | |
<!– static –>
<!– static –>
<!– static –>
<!– static –>
point | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
<!– static –>
<!– static –>
Type<!– System.Type –> |
<!– static –>
layerUri | Uri<!– System.Uri –> |
<!– static –>
layerStream | Stream<!– System.IO.Stream –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> | |
bufferTimeType | RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
attribution | String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –> |
This method allows you to raise the StreamLoading event. Normally events are not accessible to derived classes, so we exposed a way to raise the event as necessary through this protected method.
e | StreamLoadingEventArgs<!– ThinkGeo.MapSuite.Core.StreamLoadingEventArgs –> | This parameter represents the event arguments you want to raise the StreamLoading event with. |
Return Type |
Return Type |
AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
<!– ThinkGeo.MapSuite.Core.AdornmentLayer –> Go Back
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
LineStyle<!– ThinkGeo.MapSuite.Core.LineStyle –> |
The default value is false.
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
Return Type |
Return Type |
Return Type |
Return Type |
TextStyle<!– ThinkGeo.MapSuite.Core.TextStyle –> |
Return Type |
Return Type |
Return Type |
PointStyle<!– ThinkGeo.MapSuite.Core.PointStyle –> |
Return Type |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
Return Type |
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
