<!– Class –> This is the sub base class of AdornmentLayer. The LogoAdornmentLayer is taken as Logo map of the Map Control.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.AdornmentLayer ThinkGeo.MapSuite.Core.LogoAdornmentLayer
LogoAdornmentLayer | This method is the default constructor for the LogoAdornmentLayer. | ||
LogoAdornmentLayer | GeoImage | This is the constructor for the LogoAdormentLayer that receives a specified logo. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetDrawingLocation | GeoCanvas, Single, Single | AdornmentLayer | This method returns the drawing location of the AdornmentLayer. |
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the LogoAdornmentLayer. |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OpenCore | Layer | This method opens the Layer so that it is initialized and ready to use. |
BackgroundMask | AreaStyle | AdornmentLayer | |
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
Height | Single | AdornmentLayer | |
Image | GeoImage | ||
Location | AdornmentLocation | AdornmentLayer | This property gets and sets the drawing location of the AdornmentLayer. |
Width | Single | AdornmentLayer | |
XOffsetInPixel | Single | AdornmentLayer | This property gets and sets the X pixel offset for the AdornmentLayer. |
YOffsetInPixel | Single | AdornmentLayer | This property gets and sets the Y pixel offset for the AdornmentLayer. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| image | GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> | This parameter represents the logo to be drawn on the map. |
| ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | It returns the upper left screen point of where the AdornmentLayer will be drawn. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas used in drawing. |
| adornmentWidth | Single<!– System.Single –> | This parameter is the width of the adornment. |
| adornmentHeight | Single<!– System.Single –> | This parameter is the height of the adornment |
<!– ThinkGeo.MapSuite.Core.AdornmentLayer –> Go Back
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
This virtual method is called from the concreate public method Draw. In this method draw the representation of the layer based on the extent you provided.
You can use the full power of the AdornmentLayer to do the drawing.
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | This parameter are the labels used for collision detection and duplication check |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
| AreaStyle<!– ThinkGeo.MapSuite.Core.AreaStyle –> |
The default value is false.
<!– ThinkGeo.MapSuite.Core.LogoAdornmentLayer –> Go Back
| AdornmentLocation<!– ThinkGeo.MapSuite.Core.AdornmentLocation –> |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
