thinkgeo.mapsuite.core.linestyle
ThinkGeo.MapSuite.Core.LineStyle
This class is the style used to draw lines.
    • ThinkGeo.MapSuite.Core.Style
      • ThinkGeo.MapSuite.Core.LineStyle
LineStyle
  • Parameters:N/A
  • DeclaringType:N/A
  • Summary:This is a constructor for the class.
LineStyle
  • Parameters:GeoPen
  • DeclaringType:N/A
LineStyle
  • Parameters:GeoPen,GeoPen
  • DeclaringType:N/A
LineStyle
  • Parameters:GeoPen,GeoPen,GeoPen
  • DeclaringType:N/A
CloneDeep
  • Parameters:N/A
  • DeclaringType:Style
  • Summary:N/A
Draw
Draw
DrawSample
DrawSample
Equals
  • Parameters:Object
  • DeclaringType:Object
  • Summary:N/A
GetHashCode
  • Parameters:N/A
  • Summary:N/A
GetRequiredColumnNames
  • Parameters:N/A
  • Summary:N/A
GetType
  • Parameters:N/A
  • Summary:N/A
SaveStyle
  • Parameters:String
  • Summary:N/A
SaveStyle
  • Parameters:Stream
  • Summary:N/A
ToString
  • Parameters:N/A
  • Summary:N/A
CloneDeepCore
  • Parameters:N/A
  • Summary:N/A
DrawCore
DrawSampleCore
Finalize
  • Parameters:N/A
  • Summary:N/A
GetRequiredColumnNamesCore
  • Parameters:N/A
  • Summary:N/A
MemberwiseClone
  • Parameters:N/A
  • Summary:N/A
CenterPen
  • Return:GeoPen
  • Summary:This property gets and sets the center pen for the line.
CenterPenDrawingLevel
CustomLineStyles
  • Return:Collection<LineStyle>
  • Summary:This property returns a collection of line styles, allowing you to stack multiple line styles on top of each other.
Filters
  • Return:Collection<String>
  • Summary:N/A
InnerPen
  • Return:GeoPen
  • Summary:This property gets and sets the inner pen for the line.
InnerPenDrawingLevel
IsActive
  • Return:Boolean
  • Summary:N/A
  • Return:String
  • Summary:N/A
OuterPen
  • Return:GeoPen
  • Summary:This property gets and sets the outer pen for the line.
OuterPenDrawingLevel
RequiredColumnNames
  • Summary:N/A
XOffsetInPixel
  • Return:Single
  • Summary:This property gets and sets the X pixel offset for drawing each feature.
YOffsetInPixel
  • Return:Single
  • Summary:This property gets and sets the Y pixel offset for drawing each feature.
FiltersCore
  • Summary:N/A
uBs=
  • Return:Boolean
  • Summary:N/A
LineStyle()
LineStyle(GeoPen)
Use this when you do not need any additional pens to draw the feature.
outerPen
  • Type:GeoPen
  • Description:This parameter is the outer pen used to draw the feature. Go Back === LineStyle(GeoPen,GeoPen) === This is a constructor for the class. ==== Remarks ==== This is a common constructor for drawing roads. ==== Parameters ==== outerPen * Type:GeoPen * Description:This parameter is the outer pen used to draw the feature.
innerPen
  • Type:GeoPen
  • Description:This parameter is the inner pen used to draw the feature. Go Back === LineStyle(GeoPen,GeoPen,GeoPen) === This is a constructor for the class. ==== Remarks ==== This is common for drawing low level highways with center lines. ==== Parameters ==== outerPen * Type:GeoPen * Description:This parameter is the outer pen used to draw the feature.
innerPen
  • Type:GeoPen
  • Description:This parameter is the inner pen used to draw the feature. centerPen * Type:GeoPen * Description:This parameter is the center pen used to draw the feature.
Go Back
CloneDeep()
  • Return Type:Style
  • Return Type:Void
features
  • Type:IEnumerable<Feature>
canvas
labelsInThisLayer
labelsInAllLayers
Go Back
  • Return Type:Void
shapes
  • Type:IEnumerable<BaseShape>
canvas
labelsInThisLayer
labelsInAllLayers
Go Back
  • Return Type:Void
canvas
drawingExtent
Go Back
DrawSample(GeoCanvas)
  • Return Type:Void
canvas
Go Back
  • Return Type:Boolean
obj
Go Back
  • Return Type:Int32
GetRequiredColumnNames()
  • Return Type:Collection<String>
  • Return Type:Type
SaveStyle(String)
  • Return Type:Void
filePathName
Go Back
SaveStyle(Stream)
  • Return Type:Void
stream
  • Type:Stream
Go Back
  • Return Type:String
CloneDeepCore()
  • Return Type:Style
  • Return Type:Void
  • Description:None
features
canvas
  • Type:GeoCanvas
labelsInThisLayer
labelsInAllLayers
Go Back
This method draws a sample feature on the canvas you provided.
This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area. When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
  • Return Type:Void
  • Description:None
canvas
  • Type:GeoCanvas
drawingExtent
Go Back
  • Return Type:Void
GetRequiredColumnNamesCore()
  • Return Type:Object
CenterPen
You can set an inner, outer and center pen to give you a nice effect. The outer pen draws first, and should typically be black and larger then the inner pen. The inner pen draws next, and should be set as the color of the road you want. It should be thinner than the outer pen. The center pen draws last, and is used to represent a centerline in the road. We suggest that you only use the center pen for highways at low zoom level, as the dashed pen has some performance penalties.
Return Type:GeoPen
Go Back
Return Type:DrawingLevel
Go Back
CustomLineStyles
Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
Return Type:Collection<LineStyle>
Go Back
Filters
Go Back
InnerPen
Return Type:GeoPen
Go Back
Go Back
IsActive
Return Type:Boolean
Go Back
Return Type:String
Go Back
OuterPen
Return Type:GeoPen
Go Back
Go Back
RequiredColumnNames
Go Back
XOffsetInPixel
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type:Single
Go Back
YOffsetInPixel
This property allows you to specify an Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type:Single
Go Back
FiltersCore
Go Back
uBs=
Return Type:Boolean
Go Back
thinkgeo.mapsuite.core.linestyle.1442486057.txt.gz · Last modified: 2015/09/17 10:34 by admin
