<!– Class –> This class is the style used to draw lines.
This class is commonly used to draw lines on the GeoCanvas. It is specialized for drawing roads, as this is the main kind of line feature that is most often drawn. You can set an inner, outer and center pen to give you a nice effect. The outer pen draws first, and should typically be black and larger then the inner pen. The inner pen draws next, and should be set as the color of the road you want. It should be thinner than the outer pen. The center pen draws last, and is used to represent a centerline in the road. We suggest that you only use the center pen for highways at low zoom level, as the dashed pen has some performance penalties.
*System.Object ThinkGeo.MapSuite.Core.Style *ThinkGeo.MapSuite.Core.LineStyle
CloneDeep | Style | Create a copy of style using the deep clone process. | |
Draw | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
Draw | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
DrawSample | GeoCanvas, DrawingRectangleF | Style | This method draws a sample feature on the canvas you provided. |
DrawSample | GeoCanvas | Style | |
GetRequiredColumnNames | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
![]() LoadStyle | Uri | Style | |
![]() LoadStyle | Stream | Style | |
SaveStyle | String | Style | |
SaveStyle | Stream | Style | |
CloneDeepCore | Style | Create a copy of style using the deep clone process. The default implementation method uses serialization. | |
DrawCore | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
DrawSampleCore | GeoCanvas, DrawingRectangleF | Style(overriden) | This method draws a sample feature on the canvas you provided. |
GetRequiredColumnNamesCore | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
CenterPen | GeoPen | This property gets and sets the center pen for the line. | |
CenterPenDrawingLevel | DrawingLevel | ||
CustomLineStyles | Collection<LineStyle> | This property returns a collection of line styles, allowing you to stack multiple line styles on top of each other. | |
Filters | Collection<String> | Style | |
InnerPen | GeoPen | This property gets and sets the inner pen for the line. | |
InnerPenDrawingLevel | DrawingLevel | ||
IsActive | Boolean | Style | This property gets and sets the active status of the style. |
Name | String | Style | This property gets and set the name of the style. |
OuterPen | GeoPen | This property gets and sets the outer pen for the line. | |
OuterPenDrawingLevel | DrawingLevel | ||
RequiredColumnNames | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
XOffsetInPixel | Single | This property gets and sets the X pixel offset for drawing each feature. | |
YOffsetInPixel | Single | This property gets and sets the Y pixel offset for drawing each feature. |
FiltersCore | Collection<String> | Style |
This constructor allows you to pass in a single outer pen. Use this when you do not need any additional pens to draw the feature.
| outerPen | GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –> | This parameter is the outer pen used to draw the feature. |
This constructor allows you to pass in an outer and inner pen. This is common for drawing roads.
This is a common constructor for drawing roads.
This constructor allows you to pass in an outer, inner and center pen. This is common for drawing low level highways with center lines.
| innerPen | GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –> | This parameter is the inner pen used to draw the feature. |
| centerPen | GeoPen<!– ThinkGeo.MapSuite.Core.GeoPen –> | This parameter is the center pen used to draw the feature. |
| Style<!– ThinkGeo.MapSuite.Core.Style –> | A cloned style. |
<!– ThinkGeo.MapSuite.Core.Style –> Go Back
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | This parameter represents the features you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
| labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | The labels will be drawn in all layers. |
| shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
This method is the concrete wrapper for the abstract method DrawSampleCore. In this method we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
| drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.Core.DrawingRectangleF –> |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
<!– static –>
| styleUri | Uri<!– System.Uri –> |
<!– static –>
| styleStream | Stream<!– System.IO.Stream –> |
| filePathName | String<!– System.String –> |
| stream | Stream<!– System.IO.Stream –> |
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.Core.Style(overriden) –> Go Back
This virtual method is called from the concrete public method Draw. In this method, we draw a sample style on the canvas you provided. This is typically used to display a legend or other sample area.
When implementing this virtual method, consider the canvas size and draw the sample image appropriately. You should keep in mind that the sample typically shows up on a legend.
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
<!– ThinkGeo.MapSuite.Core.LineStyle –> Go Back
| DrawingLevel<!– ThinkGeo.MapSuite.Core.DrawingLevel –> |
Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
| Collection<LineStyle><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.LineStyle} –> |
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
This property allows you to specify an Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
