<!– Class –> This is the event arguments class for the LayersDrawn event on the MapEngine class. It is raised after all of the layers are drawn.
This is the event arguments class for the LayersDrawn event on the MapEngine class. It is raised after the layers are drawn. This event allows you to draw something with the canvas after all of the Layers are drawn.
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.LayersDrawnEventArgs
LayersDrawnEventArgs | This is a constructor for the class. | ||
LayersDrawnEventArgs | IEnumerable<Layer>, RectangleShape, Object | This is a constructor for the class. |
Layers | IEnumerable<Layer> | This property gets and sets the layers that have been drawn. | |
NativeImage | Object | This property gets and sets the GeoImage or native image we are drawing on. | |
WorldExtent | RectangleShape | This property gets and sets the world extent to draw. |
This constructor allows you to set the layers that were drawn, the world extent, and the image you are drawing on.
| layers | IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Layer} –> | This parameter is the layers that were drawn. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the world extent you are drawing. |
| nativeImage | Object<!– System.Object –> | This parameter is the GeoImage or native map image. |
<!– ThinkGeo.MapSuite.Core.LayersDrawnEventArgs –> Go Back
