<!– Class –> This is the event arguments class for the LayerDrawn event on the MapEngine class. It is raised after a layer is drawn.
This is the event arguments class for the LayerDrawn event on the MapEngine class. It is raised after the layer is drawn. This event allows you to manipulate the Layer, or draw something with the canvas after the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.LayerDrawnEventArgs
LayerDrawnEventArgs | This is a constructor for the class. | ||
LayerDrawnEventArgs | Layer, RectangleShape, Object | This is a constructor for the class. |
CurrentLayer | Layer | This property gets and sets layer that has drawn. | |
NativeImage | Object | This property gets and sets the GeoImage or native image that we are drawing on. | |
WorldExtent | RectangleShape | This property gets and sets the world extent to draw. |
This constructor allows you to set the Layer to be drawn, the world extent, and the image you are drawing on.
| currentLayer | Layer<!– ThinkGeo.MapSuite.Core.Layer –> | This parameter is the layer that has drawn. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the world extent that has drawn. |
| nativeImage | Object<!– System.Object –> | This parameter is the GeoImage or native map image. |
<!– ThinkGeo.MapSuite.Core.LayerDrawnEventArgs –> Go Back
