thinkgeo.mapsuite.core.labelinformation
ThinkGeo.MapSuite.Core.LabelInformation
<!– Class –> This class represents the location of a piece of a label that may be drawn.
This class is used within the labeling logic, specifically in the labeling candidate. The object may represent an entire label or, in the case of a label spline, a single character in the label.
Public MethodLabelInformation This is the constructor for the class.
Public MethodLabelInformation PointShape, String, Double This is the constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyPositionInScreenCoordinates PointShape This property gets and sets the position of a piece of a label, in screen coordinates.
Public PropertyRotationAngle Double This property gets and sets the angle of rotation for the label.
Public PropertyText String This property gets and sets the text of the label.
LabelInformation()
Overloads
If you use this constructor, you should set the various properties manually.
Name Type Description
Go Back
LabelInformation(PointShape, String, Double)
Overloads
This constructor allows you to set all of the class properties.
positionInScreenCoordinates PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the position of the label that may draw.
text String<!– System.String –> This parameter is the text for the label.
rotationAngle Double<!– System.Double –> This parameter is the angle of rotation for the label.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
Return Type
<!– ThinkGeo.MapSuite.Core.LabelInformation –> Go Back
RotationAngle
This could be the rotation of the entire label text, a single character, or a set of characters.
Return Type
Text
This may be the entire label text or a single character.
Return Type
thinkgeo.mapsuite.core.labelinformation.1440040129.txt.gz · Last modified: 2015/09/17 10:33 (external edit)
