thinkgeo.mapsuite.core.kmllayer
ThinkGeo.MapSuite.Core.KmlLayer
Class KmlLayer.
      • ThinkGeo.MapSuite.Core.KmlLayer
KmlLayer()
KmlLayer(String)
  • kmlPathFilename
    • Description:The KML path filename.
KmlLayer(String,Encoding)
  • kmlPathFilename
  • encoding
    • Type:Encoding
    • Description:The encoding.
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
CreateKmlFile(String)
Creates the KML file.
  • pathFilename
    • Description:The path filename.
CreateKmlFile(String,Encoding)
  • pathFilename
  • encoding
    • Type:Encoding
CreateKmlFile(String,FeatureLayer)
  • pathFilename
  • featureLayer
CreateKmlFile(String,FeatureLayer,KmlFileType)
  • pathFilename
  • featureLayer
  • kmlFileType
CreateKmlFile(String,FeatureLayer,KmlFileType,Encoding)
  • pathFilename
  • featureLayer
  • kmlFileType
  • encoding
    • Type:Encoding
CreateKmlFile(String,RasterLayer)
  • pathFilename
  • rasterLayer
CreateKmlFile(String,RasterLayer,KmlFileType)
  • pathFilename
  • rasterLayer
  • kmlFileType
CreateKmlFile(String,IEnumerable<MapShape>)
  • pathFilename
  • mapShapes
    • Type:IEnumerable<MapShape>
    • Description:The map shapes.
CreateKmlFile(String,IEnumerable<MapShape>,KmlFileType)
  • pathFilename
  • mapShapes
  • kmlFileType
CreateKmlFile(String,IEnumerable<MapShape>,KmlFileType,Encoding)
  • pathFilename
  • mapShapes
  • kmlFileType
  • encoding
    • Type:Encoding
AddLayerToKml(FeatureLayer,String)
Adds the layer to KML.
  • featureLayer
  • pathFilename
AddLayerToKml(RasterLayer,String)
  • rasterLayer
  • pathFilename
AddLayerToKml(AdornmentLayer,String)
  • pathFilename
AddMapShapesToKml(IEnumerable<MapShape>,String)
Adds the map shapes to KML.
  • MapShapes
  • pathFilename
AddLayersToKml(IEnumerable<Layer>,String)
Adds the layers to KML.
  • layers
    • Type:IEnumerable<Layer>
    • Description:The layers.
  • pathFilename
OpenCore()
  • Description:None
CloseCore()
This method closes the Layer and releases any resources it was using.
This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
  • Description:None
This method draws the Layer.
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
GetBoundingBoxCore()
This method returns the bounding box of the Layer.
  • Description:This method returns the bounding box of the Layer.
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
Encoding
Gets the encoding.
  • Type:Encoding
KmlPathFilename
Gets or sets the KML path filename.
HasBoundingBox
This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The default value is false.
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
IsOpenCore
StreamLoading Occurs when [stream loading].
DrawingException N/A
DrawingProgressChanged N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
RequestedDrawing N/A
RequestingDrawing N/A
thinkgeo.mapsuite.core.kmllayer.1442797582.txt.gz · Last modified: 2015/09/21 01:06 by admin
