<!– Class –> This class represents a .JP2 (JPEG2000) image type to be drawn on the map.
JPEG2000 files are fairly common in the GIS community.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.RasterLayer ThinkGeo.MapSuite.Core.EcwRasterLayer *ThinkGeo.MapSuite.Core.Jpeg2000RasterLayer
Jpeg2000RasterLayer | This is a constructor for the class. | ||
Jpeg2000RasterLayer | String | This is a constructor for the class. | |
Jpeg2000RasterLayer | String, String | This is a constructor for the class. | |
Jpeg2000RasterLayer | String, RectangleShape | This is a constructor for the class. |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetHorizontalResolution | RasterLayer | This method returns the horizontal resolution of the image. | |
GetProjectionText | RasterLayer | This method returns the projection parameters of the current layer. | |
GetVerticalResolution | RasterLayer | This method returns the vertical resolution of the image. | |
![]() LoadLayer | Stream | Layer | |
![]() LoadLayer | Uri | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
HasBoundingBox | Boolean | Layer(overriden) | |
HasProjectionText | Boolean | RasterLayer | This property returns true if the RasterLayer contains projection parameters and false if it does not contain any projection parameters. |
ImageSource | RasterSource | RasterLayer | This property gets and sets the ImageSource used by the RasterLayer. |
LowerThreshold | Double | RasterLayer | This property gets and sets the lower threshold in the scale at which to display the image. |
PathFilename | String | EcwRasterLayer | This property gets and sets the path and filename of the ECW file you want to use. |
UpperThreshold | Double | RasterLayer | This property gets and sets the upper threshold in the scale at which to display the image. |
IsOpenCore | Boolean | Layer(overriden) |
This is the default constructor. If you use this constructor, then you need to set the PathFileName property manually before using the layer.
This constructor allows you to provide the path and filename information for the JP2 file.
| imagePathFilename | String<!– System.String –> | This parameter is the path and filename of the JP2 file you want to use. |
This constructor allows you to provide the path and filename information for both the JP2 image and its world file.
| imagePathFilename | String<!– System.String –> | This parameter is the path and filename of the JP2 image file you want to use. |
| worldFilePathFilename | String<!– System.String –> | This parameter is the world file path and filename for the JP2 image you want to use. |
This constructor allows you to provide the path and filename for the JP2 image file and the image extent to use.
| imageExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the image extent of JP2 image file you want to use. |
| Single<!– System.Single –> | This method returns the horizontal resolution of the image. |
<!– ThinkGeo.MapSuite.Core.RasterLayer –> Go Back
| String<!– System.String –> | This method returns the projection parameters of the current layer. |
| Single<!– System.Single –> | This method returns the vertical resolution of the image. |
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
The set for this property is protected and only intended to be used by developers who are creating their own ImageSources. This is the main property to set for developers who are creating their own RasterLayer derivatives.
| RasterSource<!– ThinkGeo.MapSuite.Core.RasterSource –> |
Below the lower threshold in scale, the image will not be displayed. This, in conjunction with the UpperThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
This should be the complete path and filename for an ECW file.
<!– ThinkGeo.MapSuite.Core.EcwRasterLayer –> Go Back
Above the upper threshold in scale, the image will not be displayed. This, in conjunction with the LowerThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
