<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.IsoLineLayer ThinkGeo.MapSuite.Core.InMemoryGridIsoLineLayer
| Name | Parameters | DeclaringType | Summary | |
InMemoryGridIsoLineLayer | ||||
InMemoryGridIsoLineLayer(GridCell[,) | InMemoryGridIsoLineLayer]] | GridCell[, ] | ||
InMemoryGridIsoLineLayer(GridCell[,, Double) | InMemoryGridIsoLineLayer]] | GridCell[, ], Double | ||
InMemoryGridIsoLineLayer(GridCell[,, IEnumerable<Double>) | InMemoryGridIsoLineLayer]] | GridCell[, ], IEnumerable<Double> | ||
InMemoryGridIsoLineLayer(GridCell[,, IEnumerable<Double>, Double) | InMemoryGridIsoLineLayer]] | GridCell[, ], IEnumerable<Double>, Double | ||
InMemoryGridIsoLineLayer(GridCell[,, IEnumerable<Double>, Double, Double) | InMemoryGridIsoLineLayer]] | GridCell[, ], IEnumerable<Double>, Double, Double | ||
InMemoryGridIsoLineLayer(GridCell[,, IEnumerable<Double>, Double, Double, Double) | InMemoryGridIsoLineLayer]] | GridCell[, ], IEnumerable<Double>, Double, Double, Double | ||
InMemoryGridIsoLineLayer(GridCell[,, IEnumerable<Double>, Double, Double, Double, IsoLineType) | InMemoryGridIsoLineLayer]] | GridCell[, ], IEnumerable<Double>, Double, Double, Double, IsoLineType |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | ||
Close | Layer | This method closes the Layer and releases any resources it was using. | ||
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. | |
Equals | Object | Object | ||
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | ||
GetHashCode | Object | |||
![]() GetIsoFeatures(GridCell[,, IEnumerable<Double>, String, IsoLineType) | GetIsoFeatures]] | GridCell[, ], IEnumerable<Double>, String, IsoLineType | IsoLineLayer | |
![]() GetIsoFeatures | GridFeatureSource, IEnumerable<Double>, String, IsoLineType | IsoLineLayer | ||
![]() GetIsoFeatures(GridCell[,, IEnumerable<Double>, String, IsoLineType, Double) | GetIsoFeatures]] | GridCell[, ], IEnumerable<Double>, String, IsoLineType, Double | IsoLineLayer | |
GetIsoLineFeatures | ||||
![]() GetIsoLineLevels | Dictionary<PointShape, Double>, Int32 | IsoLineLayer | ||
![]() GetIsoLineLevels | IEnumerable<Double>, Int32 | IsoLineLayer | ||
![]() GetIsoLineLevels(GridCell[,, Int32) | GetIsoLineLevels]] | GridCell[, ], Int32 | IsoLineLayer | |
GetType | Object | |||
![]() LoadLayer | Stream | Layer | ||
![]() LoadLayer | Uri | Layer | ||
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | ||
RequestDrawing | TimeSpan | Layer | ||
RequestDrawing | IEnumerable<RectangleShape> | Layer | ||
RequestDrawing | RectangleShape, TimeSpan | Layer | ||
RequestDrawing | RectangleShape | Layer | ||
RequestDrawing | Layer | |||
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | ||
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | ||
CloseCore | Layer | This method closes the Layer and releases any resources it was using. | |
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
GetFeaturesForDrawingCore | GeoCanvas, Collection<SimpleCandidate> | IsoLineLayer(overriden) | |
MemberwiseClone | Object | ||
OpenCore | Layer(overriden) |
CustomStyles | Collection<Style> | IsoLineLayer | |
DataValueColumnName | String | IsoLineLayer | |
GridMatrix | GridCell[,] | ||
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
IsoLineLevels | Collection<Double> | IsoLineLayer | |
IsoLineType | IsoLineType | IsoLineLayer | |
LowerScale | Double | IsoLineLayer | |
NoDataValue | Double | IsoLineLayer | |
UpperScale | Double | IsoLineLayer |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| gridMatrix | GridCell[,]<!– ThinkGeo.MapSuite.Core.GridCell, –> | |
| isoLineLevels | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> | |
| lowerScale | Double<!– System.Double –> | |
| upperScale | Double<!– System.Double –> | |
| noDataValue | Double<!– System.Double –> | |
| isoLineType | IsoLineType<!– ThinkGeo.MapSuite.Core.IsoLineType –> |
<!– static –>
| Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Feature} –> |
| dataValueColumnName | String<!– System.String –> | |
<!– ThinkGeo.MapSuite.Core.IsoLineLayer –> Go Back
<!– static –>
| gridFeatureSource | GridFeatureSource<!– ThinkGeo.MapSuite.Core.GridFeatureSource –> | |
<!– static –>
| isoLineType | IsoLineType<!– ThinkGeo.MapSuite.Core.IsoLineType –> | |
<!– ThinkGeo.MapSuite.Core.InMemoryGridIsoLineLayer –> Go Back
<!– static –>
| Collection<Double><!– System.Collections.ObjectModel.Collection{System.Double} –> |
| dataPoints | Dictionary<PointShape,Double><!– System.Collections.Generic.Dictionary{ThinkGeo.MapSuite.Core.PointShape,System.Double} –> | |
| isoLineLevelCount | Int32<!– System.Int32 –> |
<!– static –>
| dataValues | IEnumerable<Double><!– System.Collections.Generic.IEnumerable{System.Double} –> | |
<!– static –>
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
<!– ThinkGeo.MapSuite.Core.IsoLineLayer(overriden) –> Go Back
| Collection<Style><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Style} –> |
The default value is false.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
