This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
If you use this constructor, you have to set the properties manually.
bitmap
bitmapExtent
saveContainedCellsOnly
This method will clear all the tiles in the tileCache.
This method will not take effect when the ReadOnly is set to true.
This method will delete the target tile passed in.
This method overrides the logic in its base class BitmapTileCache. This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut.
tileBoundingBox
tileScale
This method returns the BitmapTile corresponding to passed in row and column.
row
column
This method will save the target tile passed in.
Return Type:String
This property gets the Cached tiles,each item is a Dictionary with scale as its key.
Return Type:ThinkGeo.MapSuite.Core.GeoCollection<T>[[System.Collections.Generic.Dictionary`2[[System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[ThinkGeo.MapSuite.Core.BitmapTile, MapSuiteCore, Version=9.0.0.0, Culture=neutral, PublicKeyToken=null, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]|GeoCollection<T>]]
Return Type:TileImageFormat
Return Type:Int16
Return Type:Bitmap
This property gets or sets the maximum tiles count, if it exceed,it will delete the old first cached tiles.
Return Type:Int32
Return Type:Bitmap
Return Type:TileAccessMode
Return Type:TileMatrix
