<!– Class –> This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
*System.Object ThinkGeo.MapSuite.Core.TileCache *ThinkGeo.MapSuite.Core.BitmapTileCache ThinkGeo.MapSuite.Core.InMemoryBitmapTileCache
InMemoryBitmapTileCache | This is the default constructor. |
ClearCache | TileCache | This method will clear all the tiles in the tileCache. | |
DeleteTile | Tile | TileCache | This method will delete the target tile passed in. |
DeleteTiles | RectangleShape | TileCache | This method will delete the tiles within the passed in worldExtent. |
GetHigherScaleTile | RectangleShape, Double | BitmapTileCache | This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut. |
GetTile | RectangleShape | BitmapTileCache | This method returns the BitmapTile corresponding to the tile bounding box passed in. |
GetTile | Int64, Int64 | BitmapTileCache | This method returns the BitmapTile corresponding to passed in row and column. |
GetTiles | RectangleShape | BitmapTileCache | This method returns all the BitmapTiles within the passed in world extent, some of which may not has bitmap. |
SaveTile | Tile | TileCache | This method will save the target tile passed in. |
SaveTiles | Bitmap, RectangleShape, Boolean | TileCache | |
SaveTiles | Bitmap, RectangleShape | TileCache | This method will save the bitmap with its extent attached into tiles. |
ClearCacheCore | TileCache(overriden) | This method will clear all the tiles in the tileCache. | |
DeleteTileCore | Tile | TileCache(overriden) | This method will delete the target tile passed in. |
GetHigherScaleTileCore | RectangleShape, Double | BitmapTileCache(overriden) | This method overrides the logic in its base class BitmapTileCache. This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut. |
GetTileCore | Int64, Int64 | BitmapTileCache(overriden) | This method returns the BitmapTile corresponding to passed in row and column. |
MemberwiseClone | Object | ||
MergeBitmaps | IEnumerable<BitmapTile>, Double | BitmapTileCache | This method will merege the passed in bitmap tiles into a larege bitmap tile. |
OnGettingCacheImage | GettingCacheImageBitmapTileCacheEventArgs | BitmapTileCache | |
OnGottenCacheImage | GottenCacheImageBitmapTileCacheEventArgs | BitmapTileCache | |
SaveTileCore | Tile | TileCache(overriden) | This method will save the target tile passed in. |
CacheId | String | TileCache | Gets or sets the id of the TileCache. |
CachedTilesByScale | GeoCollection<Dictionary<String,BitmapTile» | This property gets the Cached tiles,each item is a Dictionary with scale as its key. | |
ImageFormat | TileImageFormat | TileCache | Gets or sets the tile image format. |
JpegQuality | Int16 | TileCache | Gets or sets the Jpeg quality , this property only take effects when setting the ImageFormat to Jpeg. |
LoadingTileImage | Bitmap | TileCache | This property returns back a preset image showing the Tile is loading. |
MaximumTilesCount | Int32 | This property gets or sets the maximum tiles count, if it exceed,it will delete the old first cached tiles. | |
NoDataTileImage | Bitmap | TileCache | This property returns back a preset image showing the tile data is missing. |
TileAccessMode | TileAccessMode | TileCache | Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete |
TileMatrix | TileMatrix | TileCache | Gets or sets the TileMatrix which is used in caculation for tiles. |
If you use this constructor, you have to set the properties manually.
This method will not take effect when the ReadOnly is set to true.
<!– ThinkGeo.MapSuite.Core.TileCache –> Go Back
| tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be deleted. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent to delete all tiles within it. |
| BitmapTile<!– ThinkGeo.MapSuite.Core.BitmapTile –> | Returns the higher scale(higher zoomLevel) bitmap tile. |
| tileBoundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The parameter specifies the current tile bounding box. |
| tileScale | Double<!– System.Double –> | This parameter specifies the current tile scale. |
<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> Go Back
| BitmapTile<!– ThinkGeo.MapSuite.Core.BitmapTile –> | Returns the BitmapTile corresponding to the passed in boundingBox. |
| tileBoundingBox | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target boundingBox for the tile to fetch. |
| BitmapTile<!– ThinkGeo.MapSuite.Core.BitmapTile –> | Returns the BitmapTile corresponding to the passed in row and column. |
| row | Int64<!– System.Int64 –> | The target row for the tile to fetch. |
| column | Int64<!– System.Int64 –> | The target column for the tile to fetch. |
| Collection<BitmapTile><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.BitmapTile} –> | Returns a collection of BitmapTiles within the passed in worldExtent. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target worldExtent will be used to fetch all the BitmapTiles from. |
| tile | Tile<!– ThinkGeo.MapSuite.Core.Tile –> | The target tile to be saved. |
| bitmap | Bitmap<!– System.Drawing.Bitmap –> | |
| bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
| saveContainedCellsOnly | Boolean<!– System.Boolean –> |
| bitmap | Bitmap<!– System.Drawing.Bitmap –> | The target bitmap to be saved into tiles. |
| bitmapExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The target extent for the bitmap. |
<!– ThinkGeo.MapSuite.Core.TileCache(overriden) –> Go Back
<!– ThinkGeo.MapSuite.Core.BitmapTileCache(overriden) –> Go Back
| BitmapTile<!– ThinkGeo.MapSuite.Core.BitmapTile –> | Returns a merged bitmap tile. |
| tilesToMerge | IEnumerable<BitmapTile><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.BitmapTile} –> | The collection of tiles to be mereged. |
| scale | Double<!– System.Double –> | The target scale for result mereged bitmap tile. |
| e | GettingCacheImageBitmapTileCacheEventArgs<!– ThinkGeo.MapSuite.Core.GettingCacheImageBitmapTileCacheEventArgs –> |
| e | GottenCacheImageBitmapTileCacheEventArgs<!– ThinkGeo.MapSuite.Core.GottenCacheImageBitmapTileCacheEventArgs –> |
| GeoCollection<Dictionary<String,BitmapTile»<!– ThinkGeo.MapSuite.Core.GeoCollection{System.Collections.Generic.Dictionary{System.String,ThinkGeo.MapSuite.Core.BitmapTile}} –> |
<!– ThinkGeo.MapSuite.Core.InMemoryBitmapTileCache –> Go Back
| TileImageFormat<!– ThinkGeo.MapSuite.Core.TileImageFormat –> |
| Int16<!– System.Int16 –> |
If you want it to take effect, you need set the ReadOnly property false.
| TileAccessMode<!– ThinkGeo.MapSuite.Core.TileAccessMode –> |
| TileMatrix<!– ThinkGeo.MapSuite.Core.TileMatrix –> |
| Event Arguments |
| Event Arguments |
