Represents an object that encapsulates a Google Map layer.
This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually.
This constructor initializes a new layer and assgin a license key.
GoogleMapsLayer(String,String,String,WebProxy)
This constructor initializes a new layer and assgin a license key and initilize a cache directory.
Get picture format string which will use for request url.
GetGoogleMapsImageCore(Double,Double,Int32,Double,Double)
OnCreatingRequest(CreatingRequestGoogleMapsLayerEventArgs)
This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
Gets or sets a value represents the map type of the GoogleMaps.
Gets or sets a value represents the request timeout from the GoogleMaps server.
Gets or sets a value to access the special features of Google Maps API Premier, you must provide a client ID when accessing any of the Premier API libraries or services. When registering for Google Maps API Premier, you will receive this client ID from Google Enterprise Support. All client IDs begin with a gme- prefix.
Gets or sets a value that is unique to your client ID, please keep your key secure.
Gets or sets a value represents the image with 512*512 when no data can access.
If you set the image's size is different from 512*512, it will be compressed or stretched to 512*512.
This event is called before creating the reqeust for google maps. It is typical that user want to get the url of reqeust and modify it according to their requirements.
Event Arguments:CreatingRequestGoogleMapsLayerEventArgs
