<!– Class –> Represents an object that encapsulates a Google Map layer.
This clss uses Google Static Maps API to implement url request.
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.GoogleMapsLayer
![]() | This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually. | ||
![]() | String, String, String | This is the constructor the for the class. | |
![]() | String, String, String, WebProxy | This is the constructor the for the class. |
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | Double, Double, Int32, Double, Double | ||
![]() | Object | ||
![]() | Get picture format string which will use for request url. | ||
![]() | Object | ||
![]() ![]() | Uri | Layer | |
![]() ![]() | Stream | Layer | |
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | TimeSpan | Layer | |
![]() | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
![]() | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
![]() | TimeSpan, RequestDrawingBufferTimeType | Layer | |
![]() | Layer | ||
![]() | RectangleShape | Layer | |
![]() | RectangleShape, TimeSpan | Layer | |
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer(overriden) | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Object | ||
![]() | CreatingRequestGoogleMapsLayerEventArgs | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | SendingWebRequestEventArgs | ||
![]() | SentWebRequestEventArgs | ||
![]() | Layer(overriden) | This method opens the Layer so that it is initialized and ready to use. | |
![]() | WebRequest | ||
![]() | String | Layer | |
![]() | Single | Layer | This property gets and sets the amount of blue to apply to the image. |
![]() | String | Gets or sets a value to access the special features of Google Maps API Premier, you must provide a client ID when accessing any of the Premier API libraries or services. When registering for Google Maps API Premier, you will receive this client ID from Google Enterprise Support. All client IDs begin with a gme- prefix. | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | Single | Layer | This property gets and sets the amount of green to apply to the image. |
![]() | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Collection<GeoColor> | Layer | Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors. |
![]() | GoogleMapsMapType | Gets or sets a value represents the map type of the GoogleMaps. | |
![]() | Double | ||
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | Bitmap | Gets or sets a value represents the image with 512*512 when no data can access. | |
![]() | GoogleMapsPictureFormat | Gets or sets a value represents the image format of the image. | |
![]() | String | Gets or sets a value that is unique to your client ID, please keep your key secure. | |
![]() | BitmapTileCache | ||
![]() | Projection | ||
![]() | Single | Layer | This property gets and sets the amount of red to apply to the image. |
![]() | TimeSpan | ||
![]() | Int32 | ||
![]() | GoogleMapsTileMode | ||
![]() | Int32 | ||
![]() | Int32 | Gets or sets a value represents the request timeout from the GoogleMaps server. | |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | WebProxy | This property gets or sets the proxy used for requesting a Web Response. |
![]() | Dictionary<Int32,Bitmap> | ||
![]() | CreatingRequestGoogleMapsLayerEventArgs | This event is called before creating the reqeust for google maps. | |
Name | Type | Description |
This constructor initializes a new layer and assgin a license key.
cacheDirectory | String<!– System.String –> | The cache directory for the GoogleMapLayer. |
clientId | String<!– System.String –> | The clientId for the GoogleMapLayer. |
privateKey | String<!– System.String –> | The privateKey for the GoogleMapLayer. |
This constructor initializes a new layer and assgin a license key and initilize a cache directory.
cacheDirectory | String<!– System.String –> | cache directory which stored the cache image. |
clientId | String<!– System.String –> | |
privateKey | String<!– System.String –> | |
webProxy | WebProxy<!– System.Net.WebProxy –> |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.Core.Layer –> | A cloned Layer. |
Void<!– System.Void –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the Layer. |
Bitmap<!– System.Drawing.Bitmap –> |
longitude | Double<!– System.Double –> | |
latitude | Double<!– System.Double –> | |
zoomLevelNumber | Int32<!– System.Int32 –> | |
tileWidth | Double<!– System.Double –> | |
tileHeight | Double<!– System.Double –> |
<!– ThinkGeo.MapSuite.Core.GoogleMapsLayer –> Go Back
String<!– System.String –> | Get picture format string which will use for request url. |
Type<!– System.Type –> |
<!– static –>
layerUri | Uri<!– System.Uri –> |
<!– static –>
layerStream | Stream<!– System.IO.Stream –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> | |
bufferTimeType | RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
attribution | String<!– System.String –> |
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
e | CreatingRequestGoogleMapsLayerEventArgs<!– ThinkGeo.MapSuite.Core.CreatingRequestGoogleMapsLayerEventArgs –> |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –> |
e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> |
e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
WebResponse<!– System.Net.WebResponse –> |
webRequest | WebRequest<!– System.Net.WebRequest –> |
Return Type |
Return Type |
Single<!– System.Single –> |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –> |
Return Type |
Return Type |
The default value is false.
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –> |
Return Type |
GoogleMapsMapType<!– ThinkGeo.MapSuite.Core.GoogleMapsMapType –> |
Return Type |
Return Type |
If you set the image's size is different from 512*512, it will be compressed or stretched to 512*512.
Return Type |
Return Type |
GoogleMapsPictureFormat<!– ThinkGeo.MapSuite.Core.GoogleMapsPictureFormat –> |
Return Type |
Return Type |
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
Return Type |
Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
GoogleMapsTileMode<!– ThinkGeo.MapSuite.Core.GoogleMapsTileMode –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Dictionary<Int32,Bitmap><!– System.Collections.Generic.Dictionary{System.Int32,System.Drawing.Bitmap} –> |
Return Type |
This event is called before creating the reqeust for google maps. It is typical that user want to get the url of reqeust and modify it according to their requirements.
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
