thinkgeo.mapsuite.core.geowrapmode
ThinkGeo.MapSuite.Core.GeoWrapMode
<!– Enumeration –> This enumeration determines how a texture is filled in with a GeoTextureBrush when the area to be filled is larger than the texture.
This will allow you to achieve a number of different effects. We suggest you try them out with your own textures and see which one looks best for your image.
Items
Name Summary
Tile The texture is tiled to fill the entire area.
Clamp The texture will not be tiled.
TileFlipX Reverse the texture horizontally and then tile the texture.
TileFlipY Reverse the texture vertically and then tile the texture.
TileFlipXY Reverse the texture horizontally and vertically and then tile the texture.
NOTOC MapSuiteCore ThinkGeo.MapSuite.Core
thinkgeo.mapsuite.core.geowrapmode.1440040128.txt.gz · Last modified: 2015/09/17 10:30 (external edit)
