You will use this constructor when you want to use the Tile wrap mode and you want the image fill to encompass the entire shape.
rectangleF
wrapMode
wrapMode
This property gets and sets the screen rectangle used to fill the texture.
Return Type:DrawingRectangleF
This property gets and sets the GeoImage used for the texture fill.
This property gets and sets the wrap mode that is used to determine how an area is filled if the area is larger than the texture.
Return Type:GeoWrapMode
Return Type:Int64
