<!– Class –> This class is used to fill an area with a image texture.
This class is used to fill an area with a image texture. For example, you may have a small bitmap that looks like marble, which you can then use to fill in an area feature.
![]() | GeoImage | This is a constructor for the class. | |
![]() | GeoImage, DrawingRectangleF | This is a constructor for the class. | |
![]() | GeoImage, GeoWrapMode | This is a constructor for the class. | |
![]() | GeoImage, GeoWrapMode, DrawingRectangleF | This is a constructor for the class. |
![]() | GeoBrush | Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization. | |
![]() | Object | ||
![]() | Object |
![]() | DrawingRectangleF | This property gets and sets the screen rectangle used to fill the texture. | |
![]() | GeoImage | This property gets and sets the GeoImage used for the texture fill. | |
![]() | GeoWrapMode | This property gets and sets the wrap mode that is used to determine how an area is filled if the area is larger than the texture. | |
![]() | Int64 | GeoBrush | The id of the GeoBrush. This is always used as a key when in the cached brushes. |
This overload allows you to pass in the image for the texture.
You will use this constructor when you want to use the Tile wrap mode and you want the image fill to encompass the entire shape.
Name | Type | Description |
image | GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> | This parameter is the image you want to use as the texture. |
This constructor allows you to pass in the image as well as a screen rectangle that determines how much of the area is filled.
This method allows you to pass in a rectangle in screen coordinates to determine how much of the area is textured.
rectangleF | DrawingRectangleF<!– ThinkGeo.MapSuite.Core.DrawingRectangleF –> | This parameter is a rectangle (in screen coordinates) that specifies the area you want to use for the texture. |
This constructor allows you to pass in the image and the wrap mode.
wrapMode | GeoWrapMode<!– ThinkGeo.MapSuite.Core.GeoWrapMode –> | This parameter determines the way the texture wraps when the area to fill is larger than the texture. |
This constructor allows you to pass in the image as well as a screen rectangle that determines how much of the area is filled along with the wrap mode.
Return Type | Description |
GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> | A cloned GeoBrush. |
<!– ThinkGeo.MapSuite.Core.GeoBrush –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.Core.GeoTextureBrush –> Go Back
Return Type |
Return Type |
Return Type |
Int64<!– System.Int64 –> |
