![]() | This is the constructor used to create a new GeoSolidBrush. | ||
![]() | GeoColor | This is the constructor used to create a new GeoSolidBrush. |
![]() | GeoBrush | Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization. | |
![]() | Object | ||
![]() | Object |
This constructor creates a GeoSolidBrush in the color black.
Name | Type | Description |
This constructor creates a GeoSolidBrush by passing in a GeoColor.
color | GeoColor | This parameter represent the color of the GeoSolidBrush. |
Return Type | Description |
GeoBrush | A cloned GeoBrush. |
Boolean |
obj | Object |
Int32 |
Type |
String |
Void |
Object |
This property gets or sets the color of the GeoSolidBrush.
The id of the GeoBrush. This is always used as a key when in the cached brushes.
Return Type |
Int64 |
