thinkgeo.mapsuite.core.geosolidbrush
ThinkGeo.MapSuite.Core.GeoSolidBrush
Public MethodGeoSolidBrush This is the constructor used to create a new GeoSolidBrush.
Public MethodGeoSolidBrush GeoColor This is the constructor used to create a new GeoSolidBrush.
Public MethodCloneDeep GeoBrush Create a copy of GeoBrush using the deep clone process.
Public MethodGetType Object
Public MethodToString Object
Protected MethodCloneDeepCore GeoBrush Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization.
Public PropertyColor GeoColor This property gets or sets the color of the GeoSolidBrush.
Public PropertyId Int64 GeoBrush The id of the GeoBrush. This is always used as a key when in the cached brushes.
GeoSolidBrush()
Overloads
This constructor creates a GeoSolidBrush in the color black.
Name Type Description
Go Back
GeoSolidBrush(GeoColor)
Overloads
This constructor creates a GeoSolidBrush by passing in a GeoColor.
color GeoColor This parameter represent the color of the GeoSolidBrush.
Go Back
CloneDeep()
Return Type Description
GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> A cloned GeoBrush.
<!– ThinkGeo.MapSuite.Core.GeoBrush –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
CloneDeepCore()
Void<!– System.Void –>
Color
Return Type
GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –>
<!– ThinkGeo.MapSuite.Core.GeoSolidBrush –> Go Back
Id
Return Type
Int64<!– System.Int64 –>
thinkgeo.mapsuite.core.geosolidbrush.1440993184.txt.gz · Last modified: 2015/08/31 03:53 by admin
