thinkgeo.mapsuite.core.geoserializer
ThinkGeo.MapSuite.Core.GeoSerializer
This class serializes an object.
    • ThinkGeo.MapSuite.Core.GeoSerializer
GeoSerializer()
Creates an instance of GeoSerializer.
GeoSerializer(GeoSerializationFormatter)
Serialize(Object,String)
Serialize an object and save the serialized data to a file.
  • objectToSerialize
    • Description:The object to be serialized.
  • targetPathFileName
    • Description:The path to save the serialized data to.
Serialize(Object,Stream)
Serialize an object and save the serialized data to a stream.
  • objectToSerialize
  • targetStream
    • Type:Stream
    • Description:The stream to save the serialized data into.
Serialize(Object)
Serialize an object and save the serialized data to a string.
  • Description:The string that contains the serialized data.
  • objectToSerialize
Deserialize(String,FileAccess)
Recreates an object from a file.
  • Description:The recreated object.
  • sourcePathFileName
    • Description:The file path to deserialize from.
  • fileAccess
    • Type:FileAccess
    • Description:The FileAccess
Deserialize(Stream)
Recreates an object from a stream.
  • sourceStream
    • Type:Stream
    • Description:The Stream to deserialize from.
Deserialize(String)
Recreates an object from a string.
  • sourceString
    • Description:The string to deserialize from.
Deserialize(Uri)
Recreates an object from an Url.
  • sourceUri
    • Type:Uri
    • Description:The Url to deserialize from.
Formatter
Gets or sets the Formatter. The Formatter determines what kind of serialized data will be created.
thinkgeo.mapsuite.core.geoserializer.1442554990.txt.gz · Last modified: 2015/09/18 05:43 by admin
