This class represents a brush that fills with various patterns.
*System.Object ThinkGeo.MapSuite.Core.GeoBrush *ThinkGeo.MapSuite.Core.GeoHatchBrush
GeoHatchBrush | GeoHatchStyle, GeoColor | This is the constructor for the class. | |
GeoHatchBrush | GeoHatchStyle, GeoColor, GeoColor | This is the constructor for the class. |
CloneDeepCore | GeoBrush | Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization. | |
BackgroundColor | GeoColor | This property gets and sets the background color for the fill pattern. | |
ForegroundColor | GeoColor | This property gets and sets the foreground color for the fill pattern. | |
HatchStyle | GeoHatchStyle | This property gets and sets the pattern you want to use for the fill. | |
Id | Int64 | GeoBrush | The id of the GeoBrush. This is always used as a key when in the cached brushes. |
This constructor allows you to provide a foreground color for the pattern fill.
You will use this constructor when you want to only specify the foreground color of the pattern and leave the background transparent.
| hatchStyle | GeoHatchStyle<!– ThinkGeo.MapSuite.Core.GeoHatchStyle –> | This property is the hatch pattern you want to use to fill the area. |
| foregroundColor | GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> | This property is the foreground color you want to use for the pattern. |
This constructor allows you to provide a foreground and background color for the pattern fill.
This constructor allows you to choose both the background and foreground color for the pattern.
| backgroundColor | GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> | This property is the background color you want to use for the pattern. |
| GeoBrush<!– ThinkGeo.MapSuite.Core.GeoBrush –> | A cloned GeoBrush. |
<!– ThinkGeo.MapSuite.Core.GeoBrush –> Go Back
In this case the foreground color will be transparent.
<!– ThinkGeo.MapSuite.Core.GeoHatchBrush –> Go Back
In this case the background color will be transparent.
| Int64<!– System.Int64 –> |
