<!– Class –> (This class is not finally released, it is possible to be removed in the next public release)
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.GeneratingGridGridFeatureSourceEventArgs
*GeneratingGridGridFeatureSourceEventArgs | |||
*GeneratingGridGridFeatureSourceEventArgs | Int32, Int32, DateTime, Boolean | ||
*GeneratingGridGridFeatureSourceEventArgs | Int32, Int32, DateTime, Boolean, String |
*Equals | Object | Object | |
*GetHashCode | Object | ||
*GetType | Object | ||
*ToString | Object |
*Finalize | Object | ||
*MemberwiseClone | Object |
*Cancel | Boolean | ||
*CurrentGridIndex | Int32 | ||
*GridCount | Int32 | ||
*GridPathFileName | String | ||
*StartProcessTime | DateTime |
| gridCount | Int32<!– System.Int32 –> | |
| currentGridIndex | Int32<!– System.Int32 –> | |
| startProcessTime | DateTime<!– System.DateTime –> | |
| cancel | Boolean<!– System.Boolean –> |
| cancel | Boolean<!– System.Boolean –> | |
| gridPathFileName | String<!– System.String –> |
<!– ThinkGeo.MapSuite.Core.GeneratingGridGridFeatureSourceEventArgs –> Go Back
NOTOC Note: * – not public released, might be removed in the next release. MapSuiteCore ThinkGeo.MapSuite.Core UpdateDocumentation
