thinkgeo.mapsuite.core.filebitmaptilecache
ThinkGeo.MapSuite.Core.FileBitmapTileCache
FileBitmapTileCache()
If you use this constructor, you have to set the properties manually.
FileBitmapTileCache(String)
This is the overloads constructor.
If you use this constructor, the other properties are set with default values.
  • cacheDirectory
    • Description:This parameter specifies the cache directory of the tile cache.
FileBitmapTileCache(String,String)
  • cacheDirectory
  • cacheId
    • Description:This parameter specifies the cache id of the tile cache.
FileBitmapTileCache(String,String,TileImageFormat,TileMatrix)
This is the constructor with all the parameters needed passed in.
  • cacheDirectory
  • cacheId
  • imageFormat
    • Description:This parameter specifies the image format of the tile cahce.
  • tileMatrix
    • Description:This parameter specifies the tile matrix of the tile cache.
ClearCache(TimeSpan)
  • tileExpiration
    • Type:TimeSpan
ClearCache(Double)
  • maxSizeInMegabytes
ClearCache(TimeSpan,Double)
  • tileExpiration
    • Type:TimeSpan
GetTileImageFileNames(RectangleShape)
  • Type:Collection<String>
GetTileImageFileName(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(Bitmap,RectangleShape,Boolean)
  • bitmap
    • Type:Bitmap
  • saveContainedCellsOnly
SaveTiles(Bitmap,RectangleShape)
  • bitmap
    • Type:Bitmap
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
GetTileCore(Int64,Int64)
This method returns the BitmapTile corresponding to passed in row and column.
  • Description:Returns the BitmapTile corresponding to the passed in row and column.
  • row
    • Type:Int64
    • Description:The target row for the tile to fetch.
  • column
    • Type:Int64
    • Description:The target column for the tile to fetch.
SaveTileCore(Tile)
This method will save the target tile passed in, you could override this API to create your own logic.
  • tile
    • Type:Tile
    • Description:The target tile to be saved.
DeleteTileCore(Tile)
This method will delete the target tile passed in.
This method will not take effect when the ReadOnly is set to true.
  • tile
    • Type:Tile
    • Description:The target tile to be deleted.
8xU=(String)
  • tileImageFileName
9BU=(Bitmap)
  • Type:Byte[]
  • bitmap
    • Type:Bitmap
ClearCacheCore()
This method will clear all the tiles in the tileCache.
GetHigherScaleTileCore(RectangleShape,Double)
This method overrides the logic in its base class BitmapTileCache. This method will return the HigherScale BitmapTile which is always used for preview effects when ZoomIn or ZoomOut.
  • Description:Returns the higher scale(higher zoomLevel) bitmap tile.
  • tileBoundingBox
    • Description:The parameter specifies the current tile bounding box.
  • tileScale
    • Description:This parameter specifies the current tile scale.
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
9RU=(ImageFormat)
  • Type:ImageCodecInfo
  • format
    • Type:ImageFormat
/xU=()
CacheDirectory
Gets or sets the cache direcory.
ExpirationTime
  • Type:TimeSpan
TileMatrix
TileAccessMode
NoDataTileImage
  • Type:Bitmap
LoadingTileImage
  • Type:Bitmap
ImageFormat
JpegQuality
  • Type:Int16
CacheId
GottenCacheImage N/A
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage N/A
thinkgeo.mapsuite.core.filebitmaptilecache.1442554901.txt.gz · Last modified: 2015/09/18 05:41 by admin
