thinkgeo.mapsuite.core.fieldserializedgeoserializereventargs
ThinkGeo.MapSuite.Core.FieldSerializedGeoSerializerEventArgs
article_rating
<!– Class –>
Public MethodFieldSerializedGeoSerializerEventArgs
Public MethodFieldSerializedGeoSerializerEventArgs String, Object, Type, Object, GeoSerializationNode
Public MethodGetType Object
Public MethodToString Object
Public PropertyName String
Public PropertyNode GeoSerializationNode
Public PropertyOwner Object
Public PropertyType Type
Public PropertyValue Object
FieldSerializedGeoSerializerEventArgs()
Name Type Description
Go Back
FieldSerializedGeoSerializerEventArgs(String, Object, Type, Object, GeoSerializationNode)
name String<!– System.String –>
value Object<!– System.Object –>
type Type<!– System.Type –>
owner Object<!– System.Object –>
node GeoSerializationNode<!– ThinkGeo.MapSuite.Core.GeoSerializationNode –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Void<!– System.Void –>
Return Type
<!– ThinkGeo.MapSuite.Core.FieldSerializedGeoSerializerEventArgs –> Go Back
Node
Return Type
Owner
Return Type
Type
Return Type
Value
Return Type
thinkgeo.mapsuite.core.fieldserializedgeoserializereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
