This static class exposes a number of helpful methods when dealing with extents.
GetDrawingExtent(RectangleShape,Single,Single)
This method returns an adjusted extent based on the ratio of the screen width and height.
This function is used because the extent to draw must be the rame ratio as the screen width and height. If they are not, then the image drawn will be stretched or compressed. We always adjust the extent upwards to ensure that no matter how we adjust it, the original extent will fit within the new extent. This ensures that everything you wanted to see in the first extent is visible and maybe a bit more.
CenterAt(RectangleShape,PointShape,Single,Single)
This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
CenterAt(RectangleShape,Feature,Single,Single)
CenterAt(RectangleShape,Single,Single,Single,Single)
This method returns an adjusted extent centered on a point.
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape,PointShape,PointShape,Single,Single)
This method returns the number of pixels between two world points.
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape,Feature,Feature,Single,Single)
This method returns the number of pixels between two features.
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape,ScreenPointF,ScreenPointF,Single,Single,GeographyUnit,DistanceUnit)
This method returns the distance in world units between two screen points.
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape,Single,Single,Single,Single,Single,Single,GeographyUnit,DistanceUnit)
GetScale(RectangleShape,Single,GeographyUnit)
This method returns the current scale.
GetScale(RectangleShape,Single,GeographyUnit,Single)
GetBoundingBoxOfItems(IEnumerable<BaseShape>)
This API gets the BoundingBox of a group of BaseShapes.
GetBoundingBoxOfItems(IEnumerable<Feature>)
This API gets the BoundingBox of a group of Features.
This method returns a new extent that is zoomed in by the percentage provided.
ZoomIntoCenter(RectangleShape,Int32,PointShape,Single,Single)
This method returns an extent that is centered and zoomed in.
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
ZoomIntoCenter(RectangleShape,Int32,Feature,Single,Single)
This method returns an extent that is centered and zoomed.
ZoomIntoCenter(RectangleShape,Int32,Single,Single,Single,Single)
This method returns a new extent that is zoomed out by the percentage provided.
ZoomOutToCenter(RectangleShape,Int32,PointShape,Single,Single)
This method returns an extent that is centered and zoomed out.
ZoomOutToCenter(RectangleShape,Int32,Feature,Single,Single)
ZoomOutToCenter(RectangleShape,Int32,Single,Single,Single,Single)
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterward.
Pan(RectangleShape,PanDirection,Int32)
This method returns a panned extent.
Pan(RectangleShape,Single,Int32)
ToScreenCoordinate(RectangleShape,Double,Double,Single,Single)
This method returns screen coordinates from world coordinates.
ToScreenCoordinate(RectangleShape,RectangleShape,Single,Single)
This method returns Rectangle in screen coordinates from RectangleShape in world coordinates.
ToScreenCoordinate(RectangleShape,PointShape,Single,Single)
ToScreenCoordinate(RectangleShape,Feature,Single,Single)
ToWorldCoordinate(RectangleShape,Single,Single,Single,Single)
This method returns world coordinates from screen coordinates.
ToWorldCoordinate(RectangleShape,ScreenPointF,Single,Single)
SnapToZoomLevel(RectangleShape,GeographyUnit,Single,Single,ZoomLevelSet)
This method returns an extent that is snapped to a zoom level in the provided zoom level set.
ZoomToScale(Double,RectangleShape,GeographyUnit,Single,Single)
This method returns a extent that has been zoomed into a certain scale.
ZoomToScale(Double,RectangleShape,GeographyUnit,Single,Single,ScreenPointF)
ZoomIntoOffsetPoint(RectangleShape,Single,Single,ScreenPointF,Int32)
This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to afterward call GetDrawingExtent.
ZoomOutToOffsetPoint(RectangleShape,Single,Single,ScreenPointF,Int32)
ResizeExtent(RectangleShape,Single,Single,Single,GeographyUnit,MapResizeMode)
This method returns a RectangleShape by resize parameters.
nxk=(Double,Collection<Double>)
nxk=(Double,Collection<Double>,Double,Double)
pBk=(RectangleShape,Single,GeographyUnit)
mhk=(Double,RectangleShape,GeographyUnit,Single)
i3g=(GeoImage,DrawingRectangle,DrawingRectangleF)
