thinkgeo.mapsuite.core.encryptedfilebitmaptilecache
ThinkGeo.MapSuite.Core.EncryptedFileBitmapTileCache
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.BitmapTileCache
        • ThinkGeo.MapSuite.Core.FileBitmapTileCache
          • ThinkGeo.MapSuite.Core.EncryptedFileBitmapTileCache
EncryptedFileBitmapTileCache()
If you use this constructor, you have to set the properties manually.
EncryptedFileBitmapTileCache(String)
This is the overloads constructor.
If you use this constructor, the other properties are set with default values.
  • cacheDirectory
    • Description:This parameter specifies the cache directory of the tile cache.
EncryptedFileBitmapTileCache(String,String)
  • cacheDirectory
  • cacheId
    • Description:This parameter specifies the cache id of the tile cache.
EncryptedFileBitmapTileCache(String,String,TileImageFormat,TileMatrix)
This is the constructor with all the parameters needed passed in.
  • cacheDirectory
  • cacheId
  • imageFormat
    • Description:This parameter specifies the image format of the tile cahce.
  • tileMatrix
    • Description:This parameter specifies the tile matrix of the tile cache.
ClearCache(TimeSpan)
  • tileExpiration
    • Type:TimeSpan
ClearCache(Double)
  • maxSizeInMegabytes
ClearCache(TimeSpan,Double)
  • tileExpiration
    • Type:TimeSpan
GetTileImageFileNames(RectangleShape)
  • Type:Collection<String>
GetTileImageFileName(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(Bitmap,RectangleShape,Boolean)
  • bitmap
    • Type:Bitmap
  • saveContainedCellsOnly
SaveTiles(Bitmap,RectangleShape)
  • bitmap
    • Type:Bitmap
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
SaveTileCore(Tile)
  • tile
    • Type:Tile
GetTileCore(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
DeleteTileCore(Tile)
  • tile
    • Type:Tile
8xU=(String)
  • tileImageFileName
9BU=(Bitmap)
  • Type:Byte[]
  • bitmap
    • Type:Bitmap
ClearCacheCore()
GetHigherScaleTileCore(RectangleShape,Double)
  • tileScale
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
CacheDirectory
ExpirationTime
  • Type:TimeSpan
TileMatrix
TileAccessMode
NoDataTileImage
  • Type:Bitmap
LoadingTileImage
  • Type:Bitmap
ImageFormat
JpegQuality
  • Type:Int16
CacheId
GottenCacheImage N/A
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage N/A
thinkgeo.mapsuite.core.encryptedfilebitmaptilecache.1442821410.txt.gz · Last modified: 2015/09/21 07:43 by admin
