thinkgeo.mapsuite.core.encryptedfilebitmaptilecache
ThinkGeo.MapSuite.Core.EncryptedFileBitmapTileCache
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.BitmapTileCache
        • ThinkGeo.MapSuite.Core.FileBitmapTileCache
          • ThinkGeo.MapSuite.Core.EncryptedFileBitmapTileCache
EncryptedFileBitmapTileCache()
If you use this constructor, you have to set the properties manually.
EncryptedFileBitmapTileCache(String)
This is the overloads constructor.
If you use this constructor, the other properties are set with default values.
  • cacheDirectory
    • Description:This parameter specifies the cache directory of the tile cache.
EncryptedFileBitmapTileCache(String,String)
  • cacheDirectory
  • cacheId
    • Description:This parameter specifies the cache id of the tile cache.
EncryptedFileBitmapTileCache(String,String,TileImageFormat,TileMatrix)
This is the constructor with all the parameters needed passed in.
  • cacheDirectory
  • cacheId
  • imageFormat
    • Description:This parameter specifies the image format of the tile cahce.
  • tileMatrix
    • Description:This parameter specifies the tile matrix of the tile cache.
GetTileImageFileName(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTileImageFileNames(RectangleShape)
  • Type:Collection<String>
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(GeoImage,RectangleShape)
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
SaveTileCore(Tile)
  • tile
    • Type:Tile
GetTileCore(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
DeleteTileCore(Tile)
  • tile
    • Type:Tile
zhs=(String)
  • zxs=
0Bs=(GeoImage)
  • Type:Byte[]
ClearCacheCore()
GetHigherScaleTileCore(RectangleShape,Double)
  • tileScale
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
CacheDirectory
ExpirationTime
  • Type:TimeSpan
TileMatrix
TileAccessMode
NoDataTileImage
LoadingTileImage
ImageFormat
JpegQuality
  • Type:Int16
CacheId
yhs=
GottenCacheImage N/A
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage N/A
thinkgeo.mapsuite.core.encryptedfilebitmaptilecache.1442797384.txt.gz · Last modified: 2015/09/21 01:03 by admin
