<!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.Core.DeserializingFieldGeoSerializerEventArgs
DeserializingFieldGeoSerializerEventArgs | |||
DeserializingFieldGeoSerializerEventArgs | String, Type, Object, GeoSerializationNode |
Name | String | ||
Node | GeoSerializationNode | ||
Owner | Object | ||
Type | Type |
| name | String<!– System.String –> | |
| type | Type<!– System.Type –> | |
| owner | Object<!– System.Object –> | |
| node | GeoSerializationNode<!– ThinkGeo.MapSuite.Core.GeoSerializationNode –> |
<!– ThinkGeo.MapSuite.Core.DeserializingFieldGeoSerializerEventArgs –> Go Back
