This class represents a style based on class break values.
This is the constructor for this class.
columnName
breakValueInclusion
breakValueInclusion
features
canvas
labelsInThisLayer
labelsInAllLayers
shapes
canvas
labelsInThisLayer
labelsInAllLayers
features
canvas
labelsInThisLayer
labelsInAllLayers
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
This property gets and sets the value of if the break values are included in the break calculation.
Example: If you have a class break value set to 100 and the break value is included, then 100 is included for this break. If you set the value to excluded, then 100 would match with the break below 100 instead. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works.
Return Type:BreakValueInclusion
This property gets the collection of class breaks.
The class breaks determine which style to use, based on the break values. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works.
Return Type:Collection<ClassBreak>
This property gets and sets the column name in the FeatureSource where the data will be found for each feature.
You use this property to set the name of the column where the numeric data is stored for your features.
Return Type:String
Return Type:Collection<String>
Return Type:Boolean
Return Type:String
