<!– Class –>
*System.Object ThinkGeo.MapSuite.Core.Layer *ThinkGeo.MapSuite.Core.BingMapsLayer
BingMapsLayer | |||
BingMapsLayer | String | ||
BingMapsLayer | String, BingMapsMapType | ||
BingMapsLayer | String, BingMapsMapType, String |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetImageryUri | Int32, Int32, Int32 | ||
![]() LoadLayer | Uri | Layer | |
![]() LoadLayer | Stream | Layer | |
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
RequestDrawing | RectangleShape, TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | TimeSpan, RequestDrawingBufferTimeType | Layer | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType | Layer | |
ApplicationId | String | ||
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
Logo | GeoImage | ||
MapType | BingMapsMapType | ||
ProjectedTileCache | BitmapTileCache | ||
ProjectionFromSphericalMercator | Projection | ||
Proxy | WebProxy | ||
TimeoutInSeconds | Int32 | ||
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
| applicationId | String<!– System.String –> |
| applicationId | String<!– System.String –> | |
| mapType | BingMapsMapType<!– ThinkGeo.MapSuite.Core.BingMapsMapType –> |
| mapType | BingMapsMapType<!– ThinkGeo.MapSuite.Core.BingMapsMapType –> | |
| cacheDirectory | String<!– System.String –> |
| Uri<!– System.Uri –> |
| rowIndex | Int32<!– System.Int32 –> | |
| columnIndex | Int32<!– System.Int32 –> | |
| zoomLevelIndex | Int32<!– System.Int32 –> |
<!– ThinkGeo.MapSuite.Core.BingMapsLayer –> Go Back
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
| e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SendingWebRequestEventArgs –> |
| e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.Core.SentWebRequestEventArgs –> |
The default value is false.
| GeoImage<!– ThinkGeo.MapSuite.Core.GeoImage –> |
| BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
| Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
| WebProxy<!– System.Net.WebProxy –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
