thinkgeo.mapsuite.core.adornmentlayerdrawneventargs
ThinkGeo.MapSuite.Core.AdornmentLayerDrawnEventArgs
      • ThinkGeo.MapSuite.Core.AdornmentLayerDrawnEventArgs
AdornmentLayerDrawnEventArgs()
This is the default constructor for the class.
AdornmentLayerDrawnEventArgs(AdornmentLayer)
  • adornmentLayer
    • Description:This parameter is the AdornmentLayer that has been drawn.
AdornmentLayer
This property gets and sets the AdornmentLayer that has been drawn.
thinkgeo.mapsuite.core.adornmentlayerdrawneventargs.1442554662.txt.gz · Last modified: 2015/09/18 05:37 by admin
