<!– Class –> Provides data for the TrackStarting. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.AndroidEdition.TrackStartingTrackInteractiveOverlayEventArgs
TrackStartingTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
TrackStartingTrackInteractiveOverlayEventArgs | Vertex, Boolean | This is the commonly used constructor. |
Cancel | Boolean | This property gets or sets the action to be canceled or not. | |
StartingVertex | Vertex | This property gets or sets the started vertex when tracking shape action is being to start. |
| startingVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the started vertex when tracking shape action is being to start. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
<!– ThinkGeo.MapSuite.AndroidEdition.TrackStartingTrackInteractiveOverlayEventArgs –> Go Back
