<!– Class –> This is the default constructor of this parameter.
*System.Object System.EventArgs *ThinkGeo.MapSuite.AndroidEdition.TrackEndedTrackInteractiveOverlayEventArgs
![]() | This is the commonly used constructor. | ||
![]() | BaseShape | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Boolean | This property gets or sets the action to be canceled or not. This property has no use any more, please use the it in the TrackInteractiveOverlay.TrackEnding event. | |
![]() | BaseShape | This property gets or sets the tracked shape. |
Name | Type | Description |
trackShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter specified the tracked shape. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.AndroidEdition.TrackEndedTrackInteractiveOverlayEventArgs –> Go Back
Return Type |
