thinkgeo.mapsuite.androidedition.sqlitebitmaptilecache
ThinkGeo.MapSuite.AndroidEdition.SqliteBitmapTileCache
This class represents the base sqlite bitmap tile cache.
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.BitmapTileCache
        • ThinkGeo.MapSuite.AndroidEdition.SqliteBitmapTileCache
SqliteBitmapTileCache()
SqliteBitmapTileCache(String,String)
  • databasePathFilename
    • Description:The database path filename.
  • cacheId
    • Description:The cache identifier.
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(GeoImage,RectangleShape)
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
GetTileCore(Int64,Int64)
This abstract method returns the BitmapTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column.
  • Description:Returns the BitmapTile corresponding to the passed in row and column.
  • row
    • Type:Int64
    • Description:The target row for the tile to fetch.
  • column
    • Type:Int64
    • Description:The target column for the tile to fetch.
ClearCacheCore()
This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method.
This method will not take effect when the ReadOnly is set to true.
SaveTileCore(Tile)
This abstract method will save the target tile passed in, for each sub TileCache class must implement this method.
  • tile
    • Type:Tile
    • Description:The target tile to be saved.
DeleteTileCore(Tile)
This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method.
  • tile
    • Type:Tile
    • Description:The target tile to be deleted.
CheckExpiration(CacheEntity)
GetHigherScaleTileCore(RectangleShape,Double)
  • tileScale
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
DatabasePathFilename
Gets or sets the database path filename.
ExpirationTime
  • Type:TimeSpan
CacheId
Gets or sets the id of the TileCache.
TileMatrix
TileAccessMode
NoDataTileImage
LoadingTileImage
ImageFormat
JpegQuality
  • Type:Int16
GottenCacheImage N/A
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage N/A
thinkgeo.mapsuite.androidedition.sqlitebitmaptilecache.1442831526.txt.gz · Last modified: 2015/09/21 10:32 by admin
