<!– Class –>
*System.Object System.EventArgs *ThinkGeo.MapSuite.AndroidEdition.SentWebRequestUriTileEventArgs
SentWebRequestUriTileEventArgs | Initializes a new instance of the class. | ||
SentWebRequestUriTileEventArgs | WebResponse | Initializes a new instance of the class. |
Response | WebResponse | Gets or sets the request object |
| response | WebResponse<!– System.Net.WebResponse –> | The response. |
<!– ThinkGeo.MapSuite.AndroidEdition.SentWebRequestUriTileEventArgs –> Go Back
