thinkgeo.mapsuite.androidedition.popupoverlay
ThinkGeo.MapSuite.AndroidEdition.PopupOverlay
<!– Class –>
Public MethodPopupOverlay Initializes a new instance of the class.
Public MethodPopupOverlay IEnumerable<Popup> This is constructor of PopupOverlay class.
Public MethodClose Overlay This method will simulate the Close interaction.
Public MethodDispose Overlay This method dispose unmanaged resource used in this class.
Public MethodDraw MapArguments, OverlayRefreshType Overlay This method draws the overlay with the provided extent in world coordinate.
Public MethodGetBoundingBox Overlay This method gets a bounding box of the Overlay.
Public MethodGetType Object
Public MethodInitialize MapArguments Overlay This method initializes overlay object.
Public MethodOpen Overlay This method will simulate the Open interaction.
Public MethodPostTransform TransformArguments, MapArguments Overlay This method will simulate the PostTransform interaction.
Public MethodRefresh Overlay This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Public MethodToString Object
Protected MethodCloseCore Overlay This protected virtual method is the Core method of Close API.
Protected MethodDispose Boolean Overlay(overriden) Releases unmanaged and - optionally - managed resources.
Protected MethodDrawCore MapArguments, OverlayRefreshType Overlay(overriden) This method draws the overlay with the provided extent in world coordinate.
Protected MethodDrawException GeoCanvas, Exception Overlay This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Overlay This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodFinalize Object(overriden)
Protected MethodGetBoundingBoxCore Overlay(overriden) This method returns a bounding box to hold all popups.
Protected MethodInitializeCore MapArguments Overlay This method initializes overlay object.
Protected MethodOnDrawingException DrawingExceptionOverlayEventArgs Overlay This method raises before the overlay is drawing exception.
Protected MethodOnDrawnException DrawnExceptionOverlayEventArgs Overlay This method raises after the overlay is drawn exception.
Protected MethodOpenCore Overlay This protected virtual method is the Core method of Open API.
Protected MethodPostTransformCore TransformArguments, MapArguments Overlay(overriden) This protected virtual method is the Core method of PostTransform API.
Protected MethodRefreshCore Overlay This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Public PropertyAttribution String Overlay Gets or sets the attribution for this overlay.
Public PropertyDrawingExceptionMode DrawingExceptionMode Overlay This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
Public PropertyDrawingQuality DrawingQuality Overlay Gets or sets the drawingQuality for this overlay.
Public PropertyIsEmpty Boolean Overlay This property gets if this overlay is empty or not.
Public PropertyIsVisible Boolean Overlay Gets or sets if this overlay is visible.
Public PropertyMapArguments MapArguments Overlay Gets or sets the mapArguments for this overlay.
Public PropertyName String Overlay Gets or sets the name of this overaly.
Public PropertyOpacity Double Overlay Gets or sets the opacity for this overlay.
Public PropertyPopups GeoCollection<Popup> This property gets a collection of popup that are added into this overlay.
Public EventDrawingException DrawingExceptionOverlayEventArgs Overlay Occurs before exception is drawing on map.
Public EventDrawnException DrawnExceptionOverlayEventArgs Overlay Occurs after exception is drawn on map.
PopupOverlay()
Name Type Description
Go Back
PopupOverlay(IEnumerable<Popup>)
popups IEnumerable<Popup><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.AndroidEdition.Popup} –> This parameter indicates a collection of popup that are added into this overlay.
Go Back
Close()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay –> Go Back
Dispose()
Draw(MapArguments, OverlayRefreshType)
mapArguments MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> This parameter maintains current map information for calculating mechanism.
refreshType OverlayRefreshType<!– ThinkGeo.MapSuite.AndroidEdition.OverlayRefreshType –> This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
Boolean<!– System.Boolean –>
GetBoundingBox()
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> A RectangleShape indicating the bounding box of this overlay.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Initialize(MapArguments)
This is a wrapper method for the virtual method InitializeCore.
Open()
PostTransform(TransformArguments, MapArguments)
transformInfo TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> This parameter maintains the transfrom information for calculating transform.
Refresh()
String<!– System.String –>
CloseCore()
Dispose(Boolean)
isDisposing Boolean<!– System.Boolean –> true to release both managed and unmanaged resources; false to release only unmanaged resources.
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay(overriden) –> Go Back
DrawCore(MapArguments, OverlayRefreshType)
DrawException(GeoCanvas, Exception)
geoCanvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –>
exception Exception<!– System.Exception –>
DrawExceptionCore(GeoCanvas, Exception)
ex Exception<!– System.Exception –>
GetBoundingBoxCore()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> A RectangleShape value that to hold all popups.
InitializeCore(MapArguments)
When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
mapArgument MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –>
OnDrawingException(DrawingExceptionOverlayEventArgs)
args DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawingExceptionOverlayEventArgs –> This parameter is the event argument for DrawingException event.
OnDrawnException(DrawnExceptionOverlayEventArgs)
args DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawnExceptionOverlayEventArgs –> This parameter is the event argument for DrawingException event.
OpenCore()
PostTransformCore(TransformArguments, MapArguments)
RefreshCore()
Attribution
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingQuality
Return Type
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –>
IsEmpty
This property enhances the performance of the overlay while drawing. If is true, we will skip drawing this overlay and continue drawing the next overlay.
Return Type
IsVisible
Return Type
MapArguments
Return Type
Return Type
Opacity
Return Type
Double<!– System.Double –>
Popups
Return Type
GeoCollection<Popup><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.AndroidEdition.Popup} –>
<!– ThinkGeo.MapSuite.AndroidEdition.PopupOverlay –> Go Back
DrawingException
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
NOTOC AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
thinkgeo.mapsuite.androidedition.popupoverlay.1440040127.txt.gz · Last modified: 2015/09/21 10:32 (external edit)
