thinkgeo.mapsuite.androidedition.featurerotatingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs
Provides data for the FeatureRotating. event.
      • ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs
FeatureRotatingEditInteractiveOverlayEventArgs()
FeatureRotatingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • rotatingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be rotated.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be roated.
  • targetControlPoint
    • Description:This parameter specified the target control point to be roated.
RotatingFeature
  • This property gets or sets the Feature to be used to roated.
SourceControlPoint
  • This property gets or sets the source control point to roate.
TargetControlPoint
  • This property gets or sets the target control point to roate.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.featurerotatingeditinteractiveoverlayeventargs.1442966206.txt.gz · Last modified: 2015/09/22 23:56 by admin
