thinkgeo.mapsuite.androidedition.featurerotatingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs
Provides data for the FeatureRotating. event.
      • ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs
FeatureRotatingEditInteractiveOverlayEventArgs()
FeatureRotatingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • rotatingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be rotated.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be roated.
  • targetControlPoint
    • Description:This parameter specified the target control point to be roated.
RotatingFeature
This property gets or sets the Feature to be used to roated.
SourceControlPoint
This property gets or sets the source control point to roate.
TargetControlPoint
This property gets or sets the target control point to roate.
Cancel
thinkgeo.mapsuite.androidedition.featurerotatingeditinteractiveoverlayeventargs.1442831368.txt.gz · Last modified: 2015/09/21 10:29 by admin
