This is the derived class of the class DbfMatchingPlugIn for matching Census Block areas.
This is the derived class of the class DbfMatchingPlugIn for matching Census Block Group areas.
This is the derived class of the class DbfMatchingPlugIn for matching Census Tracts.
This is the derived class of the class DbfMatchingPlugIn for matching counties.
This class is the derived class of the MatchingPlugin class for matching street addresses.
This class is the derived class of the MatchingPlugin class for matching IP addresses.
This is the derived class of the class MatchingPlugIn for matching PostCode.
This class implements soundex matching operations. There are two columns in the DBF file that are necessary for soundex matching. The first is the soundex value generated by certain Soundex algorithms (by default this is implemented by SimplifiedSoundex). The second is the exact value.
This class is the derived class of the class DbfMatchingPlugIn for matching states.
This class encapsulates the matching operations in a DBF dataset. This class provides functions for creating and adding records and matching for DBF index files. The DBF file could contain one key column whose column name starts with “ID_” and additional columns whose column names start with “DT_”. Each DBF file should also contain two columns named “BB_CX” and “BB_CY”, which represent the longitude and latitude. If there is bounding box information, it should consist of four columns: “BB_ULX”, “BB_ULY”, “BB_LRX”, “BB_LRY” representing upper left X, upper left Y, lower right X and lower right Y. To take advantange of binary searching, records should be sorted before insertion into the DBF file.
This class is the abstract class encapsulating matching operations. The MatchingPlugIn class is the key class in the Geocoding. It formalizes the source text using GeocoderFormalizer, tries to match in some kinds of datasets and returns a MatchResult object. MatchingPlugIn can work independently or can be combined to work together with others to accomplish complicated matching requirements.
This class implements coordinate matching functions. The CoordinatesMatchingPlugin uses serveral DBF and R-Tree index files to accomplish matching operations. street.dbf: Contains non-geographic information for streets. rt2.dbf: Contains coordinate information for streets. tlid.dbf: Contains street TIGER line ID (TLID) and index in street.dbf. Sorted by TLID. zip.dbf: Contains zip code information. rt2.ids and rt2.idx: R-Tree index files for streets by zip.
This is the derived class from the Soundex class which implements a simplfied soundex algorithm.
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
This is the base class for NativeTileCache system which inherits from TileCache class.
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
A setting for MarkerStyle that contains APIs to set properties of MarkerStyleSetting using in MVC view.
A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
HtmlHelper extension for providing access to the Mvc controls inherited from MvcControlBase
A setting for WmsOverlay that contains APIs to set properties of WmsOverlaySetting using in MVC view.
A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
Represents an overlay object that gets map images from the WMS servers.
This is an asynchronous HTTP handler which is used to handle web map services.
This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
A setting for MeasureMapTool that contains APIs to set properties of MeasureMapToolSetting using in MVC view.
A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
A setting for MouseCoordinateMapTool that contains APIs to set properties of MouseCoordinateMapToolSetting using in MVC view.
A setting for MouseMapTool that contains APIs to set properties of MouseMapToolSetting using in MVC view.
A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
A setting for TouchMapTool that contains APIs to set properties of TouchMapToolSetting using in MVC view.
This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
A setting for AdornmentOverlay that contains APIs to set properties of AdornmentOverlaySetting using in MVC view.
A setting for ArcGISServerRestOverlay that contains APIs to set properties of ArcGISServerRestOverlaySetting using in MVC view.
A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
A setting for MarkerOverlay that contains APIs to set properties of MarkerOverlaySetting using in MVC view.
A setting for SimpleMarkerOverlay that contains APIs to set properties of SimpleMarkerOverlaySetting using in MVC view.
A setting for EditFeatureOverlay that contains APIs to set properties of EditFeatureOverlaySetting using in MVC view.
A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
A setting for GoogleOverlay that contains APIs to set properties of GoogleOverlaySetting using in MVC view.
A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
A setting for Overlay that contains APIs to set properties of OverlaySetting using in MVC view.
Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
This class is the base class for all classes that define the styles applied to the markers.
Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
Serves as the base class that defines the methods and properties common to all types of popups.
This class allows you to match a value with data in the feature to determine how to draw the feature.
Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
This Class defines the utility for managing, registering or adding the client script libraries and script files of Mvc application to the page.
This Class defines the utility for managing, registering or adding the Css files to the page which included the specified control.
This class provides a abstract base class to defines the fluent interface for configuring the Mvc control.
Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
Represents a small image that displays at the center of the map when the map is loading.
Represents a company logo or other logo-type image that displays in the lower right corner of the map.
Contains the different map tools as properties and acts as an entrance for setting these map controls.
The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
Represents an overlay object that gets images from Microsoft's Virtual Earth server.
Represents a FeatureOverlay whose features can be added or edited at the client side.
Serves as the base class for the overlays that contain features and paint the features at client side.
This enumeration specifies the picture formats when getting images back to client from Google Maps.
This enumeration represents which projection will use for world map kit.
This class represents a routing algorithm that is based on the Bidirectional algorithm.
This class represents the parameters passed out through the FindingServiceArea event.
This class represents the parameters passed out through the GettingTspVisitRoute event.
This layer can show start coordinates, end coordinates, a collection of in-between stops and the resulting paths with specified styles.
This class represents the result of routing. RoutingResult is the roads collection consisting of the route, turn-by-turn directions and other information like total distance and route path.
This class represents the parameters passed out through the FindingRoute event.
This class represents the parameters passed out through the BuildingRoutingData event.
This class represents a routing algorithm that is based on the Dijkstra algorithm.
This class represents the parameters passed in through the CreatedMemberNode event.
This class represents the parameters passed in through the CreatingMemberObject event.
Indicates how the default value of a member will be dealt with by the modeler.
When applied to a method, specifies that the method is called after serialization of an object graph.
When applied to a method, specifies that the method is called before serialization of an object.
This is the event arguments for the LayersDrawn event on the GeoImageApiController class. It is raised after the Layers has been drawn.
This class provides data for the click event of the HighlightFeatureOverlay class.
Allows an object to control its own serialization and deserialization to/from a JSON string.
This object hold the resources shared between tiles. We use this to inform the tile with the current extent or scale, to optimize the performance
This class represents the GoogleMapsOverlay which requests images from Google's image server by its StaticAPI.
This class represents an event argument for the GlobeButtonClick event on PanZoomBarMapTool class.
Provides data for the ControlPointSelected event.
This enumeration specified the control point type when editing a shape. The deafault value is None
This class represents an GeoImage object for WPF. It maintains an Uri and Stream for the image source.
This class represents a canvas that is used to draw geographic shapes. It is intended to be inherited for the implementation of drawing visual systems.
This class represents the event arguments for customizing mouse coordinates tool.
This enum indicates whether a zoom bar text is displayed when dragging the slider.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This class represents the base class for all classes that defines the styles applied to the markers.
This class defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class represents a collection of MarkerZoomLevel that determines the appearance of markers at different zoomlevels.
This class inherits from the Overlay abstract class. The specified overlay specifies the background information of the MapControl.
This class represents an overlay that requesting from Bing Maps Imagery Metadata Service.
This class represents an overlay that requesting from Bing Maps Imagery Service.
Represents an overlay object that gets map images from the WMTS server you specify.
This class represents an WmsOverlay which has MapSuite world map kit server integrated.
This class represents an overlay that requesting images from OpenStreet Map Service.
This class represents an event argument for drawn tile in the TileOverlay class.
This class represents an event argument for DrawingTile event in TileOverlay class.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the Overlay has been drawn.
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn.
This enumeration specifies the type of extent change that has occurred when doing interactive actions with InterativeOverlay.
This enumeration specifies the behavior that occurs when double-left-clicking on the MapControl. The default value is ZoomIn.
This enumeration specifies the behavior that occurs when double-right-clicking on the MapControl. The default value is ZoomOut.
This enumeration specifies the behavior that occurs when you left-click-and-drag on the MapControl. The default value is ZoomInWithKey.
This enumeration specifies the behavior that occurs when the mouse wheel is scrolled. The default value is Zooming.
This enumeration specifies the behavior type for panning. The default value is StandardPanning.
This enumeration specifies the behavior that occurs when you right-click-and-drag on the MapControl. The default value is ZoomOutWithKey.
This class represents the event arguments for the MarkerDragged event for SimpleMarkerOverlay.
This method is the event args for download progress when requesting images in TileOverlay.
This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
This class encapsulates the information and simple method for interative actions.
This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
This enumeration specifies the mode to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
This enumeration specifies the mode to process other overlays when doing interactive actions with InterativeOverlay.
This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
This class represents the MarkerDragging event argument for SimpleMarkerOverlay.
