The Map Suite Xamarin.Forms illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Map Suite 9.0.0.0 and higher, and will show you how to create an Mobile application using Xamarin.Forms for Map Suite iOS or Android Editions.
Before we get started, make sure you've installed the ThinkGeo Product Center and that you've either started an evaluation or activated a full license of Map Suite iOS or Android Edition. By default, this will install the Map Suite 9.0 Xamarin.Forms assemblies to C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms.
Please following our Xamarin.Forms Installation Guide for Xamarin.Forms development environment.
Let's start by creating a new Forms blank app in Microsoft Visual Studio (2012 or newer) named HelloWorld (see Figure 1). We can create the project with .NET Framework 4.5 or higher.
xamarin_forms_quickStart_Screenshot1.png|Figure 1. Creating a new project in the Visual Studio IDE.
The project HelloWorld is created in a new solution called HelloWorld. The wizard creates a single blank Application(Xamarin.Forms.Portable).
After you created a HelloWorld project, we will see three projects in the solution, please see Figure 2.
xamarin_forms_quickStart_Screenshot2.png|Figure 2. A new project for Mobile App.
We need to add MapSuiteProtableCore.dll and MapSuiteFormsEdition.dll to the “HelloWorld” project which we will work mainly. Right-click the Reference in Solution Explorer and select “Add Reference”, we can find “MapSuitePortableCore.dll” in two products(iOS or Android) at C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite AndroidSuite iOS\Current Version\Managed Assemblies. then navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms\Current Version\Managed Assemblies folder and select “MapSuiteFormsEdition.dll”.
xamarin_forms_quickStart_Screenshot3.png|Figure 3. Add Reference to HelloWorld.
For android platform, we need to add AndroidEdition.dll, MapSuiteFormsEdition.dll and MapSuiteFormsEdition.Android.dll to “HelloWorld.Droid” project. Right-click the Reference in Solution Explorer and select “Add Reference”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms\Current Version\Managed Assemblies folder and select “MapSuiteFormsEdition.Android.dll” and “MapSuiteFormsEdition.dll”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Android\Current Version\Managed Assemblies folder and select “AndroidEdition.dll”.
xamarin_forms_quickStart_Screenshot4.png|Figure 4. Add Reference to HelloWorld.Droid.
The next step is to Initialize MapSuiteForms, MainActivity.cs:
public class MainActivity : global::Xamarin.Forms.Platform.Android.FormsApplicationActivity { protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); Forms.Init(this, bundle); MapSuiteForms.Init(); LoadApplication(new App()); } }
For iOS platform, we need to add iOSEdition.dll, MapSuiteFormsEdition.dll and MapSuiteFormsEdition.iOS.dll to “HelloWorld.iOS” project. Right-click the Reference in Solution Explorer and select “Add Reference”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Xamarin Forms\Current Version\Managed Assemblies folder and select “MapSuiteFormsEdition.dll” and “MapSuiteFormsEdition.iOS.dll”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite iOS\Current Version\Managed Assemblies folder and select “iOSEdition.dll”.
xamarin_forms_quickStart_Screenshot5.png|Figure 5. Add Reference to HelloWorld.iOS.
The next step is to Initialize MapSuiteForms, AppDeleagte.cs:
<source lang=“csharp”> Register("AppDelegate") public partial class AppDelegate : global::Xamarin.Forms.Platform.iOS.FormsApplicationDelegate {
public override bool FinishedLaunching(UIApplication app, NSDictionary options)
Forms.Init();
return base.FinishedLaunching(app, options);
} </source>
The next step is to create Map view in the constructor of App, and define it as “mapView”.
<source lang=“csharp”> public App() {
MapView mapView = new MapView();
MainPage = new ContentPage
Content = new StackLayout
Children = { mapView }
} </source>
The first step in creating our “Hello World” sample application is to set references to the
ThinkGeo.MapSuite.Core
and
ThinkGeo.MapSuite.FormsEdition
workspaces at the very top of our code, since we'll use many classes within them. Set the reference like this:
<source lang=“csharp”> using ThinkGeo.MapSuite.Core; using ThinkGeo.MapSuite.FormsEdition; </source>
Now, let's add a base overlay to display the world map witch called “WorldMapKitOverlay”.
<nowiki>//</nowiki> Set the Map Unit to DecimalDegrees, the Shapefile’s unit of measure. mapView.MapUnit = GeographyUnit.DecimalDegree;
<nowiki>//</nowiki> Create a WorldMapKitOverlay. WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay();
<nowiki>//</nowiki> Add a WorldMapKitOverlay.
mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay);
<nowiki>//</nowiki> Set a proper extent for the map. The extent is the geographical area you want it to display. mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26);
Content = new StackLayout()
} </source>
If we compile and run what we have now, our map should look like the one below (see Figure 6).
xamarin_forms_quickStart_Screenshot6.png|Figure 6. A simple map of Europe (Android left, iOS right).
PresetZoomLevels has a very useful property called
ZoomLevel.ApplyUntilZoomLevel
, which you can easily use to extend your ZoomLevels. Let's say you want a particular style to be visible at ZoomLevel03 through ZoomLevel10. To make that work, simply code as follows:
<source lang=“csharp”> capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; </source>
*worldwide country borders (Countries02.shp)
Android The data used here can be found in the attached sample above in the “\AppData” folder. And we has copy data to sdcard. Please check data, and make sure we can find it in sdcard (“/mnt/sdcard/Android.Sample/”).
iOS The data used here can be found in the attached sample above in the “\AppData” folder. The data files' build action should be “Content”.
Our next step is to define and add our Layers. Here is the code to use for our example. All of the following code can be placed in the the constructor of App.
<nowiki>//</nowiki> Get the base data location on different platform.
string baseDataPath = Device.OnPlatform<string>("", "/mnt/sdcard/Android.Sample/", "");
<nowiki>//</nowiki> Create a new Layer and pass the path to a Shapefile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/Countries02.shp");
<nowiki>//</nowiki> Set the worldLayer with a preset Style, as AreaStyles.Country1 has YellowGreen background and black border, our worldLayer will have the same render style. worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1;
<nowiki>//</nowiki> This setting will apply from ZoomLevel01 to ZoomLevel20, which means the map will be rendered in the same style, no matter how far we zoom in or out. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
<nowiki>//</nowiki> Create a new Layer Overlay to hold the layer we just created LayerOverlay layerOverlay = new LayerOverlay();
<nowiki>//</nowiki> Add the shapefile layer to the layer overlay layerOverlay.Layers.Add(worldLayer);
<nowiki>//</nowiki> Add the layerOverlay to map. mapView.Overlays.Add(layerOverlay);
} </source>
If you compile and run, your map should look like the one below. (see Figure 7).
xamarin_forms_quickStart_Screenshot7.png|Figure 7. A Simple map of Europe (Android left, iOS right).
Now you can display and navigate your map. Pan by dragging the map, zoom in by double-clicking, zoom in and out with the gesture. Very powerful for just couple lines of code, isn't it?
#World country borders (“Countries02.shp”) #World capitals (“WorldCapitals.shp”)
MapView mapView = new MapView(); mapView.MapUnit = GeographyUnit.DecimalDegree;
ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/Countries02.shp"); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); <nowiki>//</nowiki> Similarly, we use the presetPointStyle for cities. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3; <nowiki>//</nowiki> This setting also applies from ZoomLevel01 to ZoomLevel20, so city symbols will be rendered in the same style, no matter how far we zoom in or out. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); <nowiki>//</nowiki> We need to add both of the new layers to the Layer OverLay. layerOverlay.Layers.Add(capitalLayer);
mapView.Overlays.Add(layerOverlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26);
} </source>
If you compile and run, your map should look like the one below. (see Figure 8).
ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); <nowiki>//</nowiki> Similarly, we use the presetPointStyle for cities. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3; <nowiki>//</nowiki> This setting also applies from ZoomLevel01 to ZoomLevel20, which means city symbols will be rendered in the same style no matter how far we <nowiki>//</nowiki>zoom in or out. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
<nowiki>//</nowiki> We create a new Layer for labeling the capitals.
ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp");
<nowiki>//</nowiki> We use the preset TextStyle. Here we pass in "CITY_NAME", the name of the field containing the values we want to label the map with.
<nowiki>//</nowiki> Since the map is drawn with tiles, the label needs to draw on the margin to make sure the text is complete after joining the tiles together.
<nowiki>//</nowiki> Change the number below (to 0, for example) to better understand how this works.
LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); layerOverlay.Layers.Add(capitalLayer); layerOverlay.Layers.Add(capitalLabelLayer);
} </source>
If you compile and run, your map should look like the one below. (see Figure 9).
ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(baseDataPath + @"AppData/WorldCapitals.shp"); <nowiki>//</nowiki> We can customize our own Style. Here we pass in a color and a size. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); <nowiki>//</nowiki> The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, it will no longer be visible. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05;
capitalLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = PointStyles.Capital3; <nowiki>//</nowiki> The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, it will no longer be visible. capitalLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
<nowiki>//</nowiki> We can customize our own TextStyle. Here we pass in the font, size, style and color.
<nowiki>//</nowiki> The TextStyle we set here is available from ZoomLevel01 to ZoomLevel05.
<nowiki>//</nowiki> The TextStyle we set here is available from ZoomLevel06 to ZoomLevel20.
} </source>
Can you imagine what the map will look like now? Below is the result. If you compile and run, at first it looks like Figure 14, then like Figure 15 as you zoom in further.
#It is of the utmost importance that the units (feet, meters, decimal degrees, etc.) be set properly for the Map control, based on the requirements of your data. #Shapefiles provide the data used by a Map control to render a map. #A Map is the basic control that contains all the other objects used to indicate how the map should be rendered. #A Map has one-to-many Layers. A Layer correlates one-to-one with a Shapefile (.shp). #A Layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges (upper and lower scales) of when a Layer should be shown or hidden.
<br>
