View Source |
In today's Wpf project, we show you how to apply the FilterStyle to a layer's display. By using this style, the map will filter the features queried from the source file by checking if a specified column value fits the input condition. This effect can be applied to all the Map Suite products.
Applies To: Desktop \ Services \ Wpf
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
